Registering a 3945 VG in CUCM 8.6 using MGCP
CSCO12060329
I have also created the gateway in CallManager with the hostname.domain where it asks for the domain name. I cannot figure out why this voice gateway is not registering in CM. Any help would be greatly appreciated!
Here is my config on the VG:
hostname XXXXX_3945_VG
boot-start-marker
boot-end-marker
card type t1 0 0
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip cef
isdn switch-type primary-ni
voice-card 0
license udi pid C3900-SPE150/K9 sn FOC15440X6L
hw-module pvdm 0/0
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
controller T1 0/0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address x.x.x.x 255.255.255.0 (Voice vlan interface)
duplex auto
speed auto
interface GigabitEthernet0/0.20
shutdown
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
ip default-gateway x.x.x.x
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 x.x.x.x
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/0:23
ccm-manager switchback immediate
ccm-manager redundant-host x.x.x.x (CM subscriber)
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server x.x.x.x (CM publisher)
ccm-manager config
mgcp
mgcp call-agent x.x.x.x (CM publisher) 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
logging synchronous
login local
transport input all
line vty 5 15
logging synchronous
login local
transport input all
scheduler allocate 20000 1000
end
CSCO12060329
Here is the output of show isdn status:
Global ISDN Switchtype = primary-ni
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-ni
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
I dont see any ip domain name command on your VG. Hence you should only use the hostname of the gateway in cucm without any domain name. You should only use domain name if you have ip domain name configured.
So I suggest you remove the .domain name on cucm and leave only the hostname. Then on the voice gateway do a no mgcp and then mgcp.
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
I tried removing the .domain in CUCM, and entering mgcp / no mgcp on the gateway. Unfortunately this did not solve the problem. Thank you for your input.
Looking closer at your debug isdn q931, I can see that layer 1 is deactivated. This suggests a physical layer issue, cabling etc. Can you check that...
