08-27-2017 09:45 PM - edited 06-23-2020 01:01 AM
03-21-2018 07:53 PM
I got the same issue on yesterday, and TAC responded to ignore that fail status message, and it does not harm to 8831
08-27-2017 11:02 PM
The phone is properly registered.
Firmware download is getting failed as the requested firmware may not be uploaded on the server.
Currently your phone is registered and has the firmware "sip8831.10-3-1SR3-5"
And it is requesting "sip8831.10-3-1SR2-2" which is getting failed as this firmware may not be present on the server.
Please let me know if I understand your query correctly or elaborate more if I haven't.
08-27-2017 11:39 PM
1) is it because the phone is new and it came with newest firmware ?
2) how to make the firmware available on the server ?
3) would the new firmware affected the older phone ?
08-28-2017 12:32 AM
1) is it because the phone is new and it came with newest firmware ? yes probably
2) how to make the firmware available on the server ? currently your phone running the latest firmware so there is no need to upload the previous version firmware for this phone.
Still below is the procedure to upload the firmware on cucm.
new firmware will not affect old IP phones. Unles you manually upload new firmware name under "phone load name" of those device. In this case these phones will upgrade to the new firmware.
Please rate if useful
08-29-2017 08:04 PM - edited 06-23-2020 01:01 AM
08-30-2017 12:38 PM
try following things one by one
1- Delete/Erase IP4 network setting
2- Delete/Erase CTL Trust files
if nothing works above then Reset Telephone Device to factory setting
09-06-2017 01:04 AM - edited 06-23-2020 01:02 AM
09-07-2017 01:40 AM
why you need to install new device pack if the phone is already appearing in phone list?
09-07-2017 02:00 AM
03-21-2018 01:56 AM
According to
Firmware Downgrade Limitation
After you install Firmware Release 10.3(1)SR3 on a conference phone, you cannot downgrade the firmware to a previous version.
03-21-2018 07:48 PM
as of now, the issues still persist
03-21-2018 07:53 PM
03-21-2018 09:55 PM
I have 5 unit of the same batch that having the same problem,
wondering if it a firmware issues
03-22-2018 01:51 AM
I believe that is the reason
