Registration failed. Max phone count reached
Dimitris Mingos
I am having a strange problem, faced for the first time and I am unable to find any documentation on solving that.
I have a brand new 2911 cme/srst router.
I start registering phones and up from the first phone I am getting the message:
"Registration failed. Max phone count reached"
I have to deliver the roter to the client by Monday!
Any help will be appreciated.
The below is what I get with show ephone reg
*Dec 19 14:38:30.847: New Skinny socket accepted [1] from 0, sub 1 (5 active)
*Dec 19 14:38:30.847: sin_family 2, sin_port 50457, in_addr 192.168.177.50
*Dec 19 14:38:30.847: skinny_add_socket 1 192.168.177.50 50457
*Dec 19 14:38:31.135: ephone-(1)[3] StationRegisterMessage (0/0/51) from 192.168.177.50
*Dec 19 14:38:31.135: ephone-(1)[3] Register StationIdentifier DeviceName SEP001F9E26A32D
*Dec 19 14:38:31.135: ephone-(1)[3] StationIdentifier Instance 0    deviceType 307
*Dec 19 14:38:31.135: fSkinnyStationRegister deviceType 307 protocolVer = 0x85720014
*Dec 19 14:38:31.135: StationJoinAndDirectTransferFeatureSupportMask set disable
*Dec 19 14:38:31.135: StationDisableJoinOnTheSameLineFeatureMask set enable
*Dec 19 14:38:31.135: StationDisableJoinAcrossLineFeatureMask set enable
*Dec 19 14:38:31.135: StationDisableDirectTransferOnTheSameLineFeatureMask set enable
*Dec 19 14:38:31.135: StationDisableDirectTransferAcrossLineFeatureMask set enable
*Dec 19 14:38:31.135: ephone-1[0/-1][SEP001F9E26A32D]:stationIpAddr 192.168.177.50
*Dec 19 14:38:31.135: ephone-1[0/-1][SEP001F9E26A32D]:stationIpv6Addr ::
*Dec 19 14:38:31.135: ephone-1[0/-1][SEP001F9E26A32D]:maxStreams 5
*Dec 19 14:38:31.135: ephone-1[0/-1][SEP001F9E26A32D]:From Phone raw protocol Ver 0x85720014
*Dec 19 14:38:31.135: ephone-1[0/-1][SEP001F9E26A32D]:protocol Ver 0x85720014
*Dec 19 14:38:31.135: ephone-1[0/-1][SEP001F9E26A32D]:phone-size 36104 dn-size 992
*Dec 19 14:38:31.135: ephone-(1) Allow any Skinny Server IP address 192.168.177.5SEP001F9E26A32D: Registration failed. Max phone count reached
*Dec 19 14:38:31.135: Failed SkinnyAssociatePhone for SEP001F9E26A32D tag 1
*Dec 19 14:38:31.135: Skinny register (phones=0/0/51) REJECT from IP 192.168.177.50
Thank you
12 Replies 12
Rob Huffman
Hi Dimitris,
Did you try setting this?
(config-telephony)#max-ephones ?
  <1-110>  Maximum phones to support
Cheers!
Rob
Hi Rob,
YES!!!!
First time used configuration professional up from start and I had that problem.
CLI is the best method I guess.
so new to new IOS features:
NTNG-2911#conf t
NTNG-2911(config)#telephony-service
NTNG-2911(config-telephony)#max-ephones 58
PLEASE  READ THE  FOLLOWING TERMS  CAREFULLY. INSTALLING THE LICENSE OR
LICENSE  KEY  PROVIDED FOR  ANY CISCO  PRODUCT  FEATURE  OR  USING SUCH
PRODUCT  FEATURE  CONSTITUTES  YOUR  FULL ACCEPTANCE  OF  THE FOLLOWING
TERMS. YOU MUST NOT PROCEED FURTHER IF YOU ARE NOT WILLING TO  BE BOUND
BY ALL THE TERMS SET FORTH HEREIN.
bla, bla, bla
Activation  of the  software command line interface will be evidence of
your acceptance of this agreement.
ACCEPT? [yes/no]: y
*Dec 19 14:59:06.243: %LICENSE-6-EULA_ACCEPTED: EULA for feature cme-srst 1.0 ha
s been accepted. UDI=CISCO2911/K9:FCZ1442706X; StoreIndex=23:Evaluation License
Storage
*Dec 19 14:59:09.379: %IPPHONE-6-REGISTER: ephone-1:SEP001F9E26A32D IP:192.168.1
77.50 Socket:2 DeviceType:Phone has registered.
*Dec 19 14:59:13.675: %LICENSE-6-EULA_ACCEPTED: EULA for feature cme-srst 1.0 ha
s been accepted. UDI=CISCO2911/K9:FCZ1442706X; StoreIndex=22:Evaluation License
Storage
AND all works fine.
THANK YOU very much,
Dimitris
@ROB - you are the man!  I was having the same problem. I had configured this using CCP and it did not take apparently.  I entered via the command line as you stated and whala!
Then accepted the EULA.  I immediately saw my phones register.  I will say I tried setting the max below the maximum number first and I never was given the EULA and nothing happened.  I then set to the Max and then I saw the EULA>
Thanks - supper happy I found this post.
Rob Huffman
Hi Dimitris,
You are most welcome my friend
Don't forget to load the "Permanent" license;
Cisco’s Integrated Services Routers Generation Two Licensing and Packaging
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985_ps10536_Products_White_Paper.html#wp9000793
Cheers!
Rob
Hi Friends,
I have this same issue... I accept  EULA, configure max-ephones but the phone can´t register in SRST mode.. this is my configuration:
call-manager-fallback
max-conferences 50 gain -6
transfer-system full-consult
ip source-address 10.8.143.21 port 2000
max-ephones 20
max-dn 20
time-zone 11
Index 3 Feature: uck9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 11 Feature: cme-srst
        Period left: 8  weeks 4  days
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA accepted
        License Count: 0/0  (In-use/Violation)
        License Priority: Low
VGW#
Jan  1 10:34:21.955: New Skinny socket accepted [1] from 0, sub 1 (0 active)
Jan  1 10:34:21.955: sin_family 2, sin_port 50033, in_addr 10.8.143.23
Jan  1 10:34:21.955: skinny_add_socket 1 10.8.143.23 50033
Jan  1 10:34:21.961: ephone-(-1)[1] StationRegisterMessage (0/0/21) from 10.8.143.23
Jan  1 10:34:21.961: ephone-(-1)[1] Register StationIdentifier DeviceName SEPB8621F6CC634
Jan  1 10:34:21.961: ephone-(-1)[1] StationIdentifier Instance 1    deviceType 434
Jan  1 10:34:21.961: fSkinnyStationRegister deviceType 434 protocolVer = 0x8570000C
Jan  1 10:34:21.961: StationJoinAndDirectTransferFeatureSupportMask set disable
Jan  1 10:34:21.961: StationDisableJoinOnTheSameLineFeatureMask set enable
Jan  1 10:34:21.961: StationDisableJoinAcrossLineFeatureMask set enable
Jan  1 10:34:21.961: StationDisableDirectTransferOnTheSameLineFeatureMask set enable
Jan  1 10:34:21.961: StationDisableDirectTransferAcrossLineFeatureMask set enable
Jan  1 10:34:21.961: ephone-(-1) Allow any Skinny Server IP address 10.8.143.21SEPB8621F6CC634: Registration failed. Max phone count reached
Jan  1 10:34:21.961: Failed SkinnyAssociatePhone for SEPB8621F6CC634 tag -1
Jan  1 10:34:21.961: Skinny register (phones=0/0/21) REJECT from IP 10.8.143.23
Jan  1 10:34:21.983:
Skinny StationAlarmMessage on socket [1] 10.8.143.23
Jan  1 10:34:21.983: severityInformational p1=0 [0x0] p2=0 [0x0]
Jan  1 10:34:21.983: 24: Nombre=SEPB8621F6CC634Carga= SCCP42.8-3-2S Zltimo=Telifono-Regis-Rech
Any help will be appreciate.
Thanks.
have you added below command and then performed reload after saving config.if not can you give a shot.
run this in config mode:
1)license boot module c2900 technology-package uck9" CLI was added
2) license accept end user agreement" acceptance and reload have been performed.
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
HI Nadeem..
I run the commands:
VGW(config)#license boot module c3900e technology-package uck9
% use 'write' command to make license boot config take effect on next boot
VGW(config)#exit
VGW#write
Building configuration...
[OK]
VGW#reload
Proceed with reload? [confirm]
*****  After Reload ******
VGW(config)#license accept end user agreement
VGW(config)#exit
VGW#write
VGW#Reload
But i see the same problem:
Jan  1 12:14:35.883: ephone-(-1)[1] StationRegisterMessage (0/0/21) from 10.8.143.24
Jan  1 12:14:35.883: ephone-(-1)[1] Register StationIdentifier DeviceName SEPB8621F6CC634
Jan  1 12:14:35.883: ephone-(-1)[1] StationIdentifier Instance 1    deviceType 434
Jan  1 12:14:35.883: fSkinnyStationRegister deviceType 434 protocolVer = 0x85720016
Jan  1 12:14:35.883: StationJoinAndDirectTransferFeatureSupportMask set disable
Jan  1 12:14:35.883: StationDisableJoinOnTheSameLineFeatureMask set enable
Jan  1 12:14:35.883: StationDisableJoinAcrossLineFeatureMask set enable
Jan  1 12:14:35.883: StationDisableDirectTransferOnTheSameLineFeatureMask set enable
Jan  1 12:14:35.883: StationDisableDirectTransferAcrossLineFeatureMask set enable
Jan  1 12:14:35.883: ephone-(-1) Allow any Skinny Server IP address 10.8.143.21SEPB8621F6CC634: Registration failed. Max phone count reached
Jan  1 12:14:35.883: Failed SkinnyAssociatePhone for SEPB8621F6CC634 tag -1
Jan  1 12:14:35.883: Skinny register (phones=0/0/21) REJECT from IP 10.8.143.24
VGW#sh lic feature
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
ipbasek9                 no           no          no             yes      no
securityk9               yes          yes         no             no       yes
uck9                     yes          yes         no             yes      yes
datak9                   yes          yes         no             no       yes
gatekeeper               yes          yes         no             no       yes
LI                       yes          no          no             no       no
SSL_VPN                  yes          yes         no             no       yes
ios-ips-update           yes          yes         yes            no       yes
SNASw                    yes          yes         no             no       yes
hseck9                   yes          no          no             no       no
cme-srst                 yes          yes         no             no       yes
UCVideo                  yes          yes         no             no       yes
Please help me.
Any can help me in this please.
I am having the exact same problem.  I have tried all suggestions given in this thread.
Any additional help appreciated.
Thank You.
Finally This works for me.
1. Copy your actual SRST configuration i.e Notepad for backup.
2. Delete all SRST configuration and reload the router.
3. Configure CUCME For SRST
> https://supportforums.cisco.com/docs/DOC-24089
4. Test CUCME SRST by stopping CallManager Service in your server.
If this work, you can now provide SRST usign CUCME. If not work reload your router and then delete all CUCME SRST
configuration.
5. Restore your SRST backup (step 1) and test.
Remember to accept the end user agreement and EULA
Good luck..
Hi.
Can you please post your IOS version and platform model?
Carlo
Please rate all helpful posts "The more you help the more you learn"
I am running C2900-UNIVERSALK8-M Ver. 15.3(3)M1 on a 2911 ISR
