06-11-2018 04:37 AM - edited 03-18-2019 12:26 PM
All,
Have just upgraded a CUCM cluster to 11.5.1 SU3b and since then I am unable to register any phones to the previously used TFTP server.
However if I use the secondary TFTP the phone registers fine. (Phone downloads CTL all OK - Mixed mode cluster, but this is a Non-Secure Profile/Phone..)
On this point also, the TFTP node with the issue has no CTL installed, the working node DOES have a CTL.. This is the only obvious inconsistency I can see.
From the phones perspective I see this:
Also Event Viewer shows me ReasonforOutOfService=14
The phone console log shows me this with an error about not finding the key for the signer:
'show itl' on this node does look OK and I can see entries within the ITL for CCM/TFTP and no invalid certs etc...
Any ideas? Possibly a bulk ITL reset/recovery?
Solved! Go to Solution.
07-16-2018 05:50 AM
06-11-2018 10:08 AM
Hi there
Does this involved any movement of phones from one cluster to another, or just an upgrade ? You could try the bulk migration method as mentioned in this doc.
The Bulk Certificate Export method works in the following way from the OS Adminstration > Security > Bulk Certificate page:
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
06-12-2018 02:54 AM
Hi Rathessh,
This is a single cluster only. The only relationship with another cluster is for EMCC purposes.
We followed the upgrade guide in Cisco documentation for 11.5.1 SU3b.
Thanks.
06-11-2018 11:40 AM
06-12-2018 02:56 AM
Hi Nipun,
The phone doesn't have an ITL, it is failing to download it on boot.
The process followed was a Standard Upgrade.
I will attempt to get the full log for you.
Thanks.
06-12-2018 05:16 AM
06-12-2018 08:04 AM
Hi Nipun,
Just to be clear, the issue is only impacting NEW phones out of the box.
Existing phones are fine.
I will obtain logs..
Thanks.
06-12-2018 08:09 AM
Hi there
What are the models you are trying to register ? whats the Boot load firmware on the phone ? Whats the phone firmware on the CUCM (Device > Device Defaults)
Hope this helps!
Cheers
Rath!
07-16-2018 05:50 AM
