Registration Rejected: Max Phones Exceeded On UC 560
esa786_2
Hi Team
Any Help on this
max phone exceed on UC 560. When i connect new phone. I need urgent help on this.
Rob Huffman
Hi Esa,
It sounds like a licensing issue to me. How many users is
the system licensed for and at what number of ephones are
you receiving the error?
"show lic detail"
"show platform software lic"
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
6 Replies 6
Under telephony-service you can check with max-ephone how many phones you can add: http://cisco.biz/en/US/docs/voice_ip_comm/cucme/command/reference/cme_m1ht.html#wp1094681
If you can't add more, you need bigger router capable of registering more phones.
Check this link for specifications: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
You can have a look at this post as well:
https://supportforums.cisco.com/thread/2141447
Message was edited by: Hermanus Janse van Vuuren
Best Regards
Sambit Khuas
Correctly said by Hermanus (+5).
In case the 'max ephone ?' command advises the number of phones you have configured already, then it is likely that we are running into a license issue.
In that case please share the output of 'sh license detail'.
It is possible that we might need to accept the EULA.
Please refer to the following for more information:
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1155517
Sam
Please rate all helpful posts.
My ephone config is below
max-ephone 114
max-dn 600
So the max-ephone is not an issue. what will be reason?
pls assist.
It UC560 device.
Rob Huffman
Hi Esa,
"show lic detail"
Cheers!
Rob
- Springsteen
Hi Rob,
Thank you for the reply. When i checked the lic command and attached with this post. It looks like, the lic issue. The total lic is 22 and used 22. please give your comment on the attched file.
Thanks in advance Rob
Esa
Rob Huffman
Hi Esa,
You are most welcome my friend
This does tell the story;
ASG-ASQ01-UC560#show platform software lic
License UDI                  : UC560-T1E1-K9:FGL154112G3
Maximum User Licenses        : 22
Used User Licenses           : 22
Available User Licenses      : 0
As the uc560 has been announced as End of Life you will need to order
an add-on user license quite soon. Something like;
L-UC-PRO-8U=
Software license upgrade, authorizing an additional 8 users (e-delivery)
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/reference_guide_c07-566560.html
End of Life notice;
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/end_of_life_notice_c51-729017.pdf
Cheers!
Rob
- Springsteen
