05-10-2016 01:24 AM - edited 03-17-2019 06:50 AM
Dear IP telephony expert,
Would you tell me the tools for remote controlling of an cisco IP phone !
I'm eagerly waiting for your reply.
Thanks in advance.
Nizam
Solved! Go to Solution.
05-10-2016 01:41 AM
I have used phoneview at one of my customer to erase itl files remotely, but this tool is also capable of remote control of IP phones.
You may see trial version on below web link.
http://www.unifiedfx.com/phoneview/trial
Suresh
05-10-2016 01:41 AM
Suresh
05-10-2016 02:33 AM
Hi Suresh,
Thanks for your reply.
We've already test through it but we could not control the IP phone of model 7942.
Would you change IP address through unifiedfx?
Nizam
05-10-2016 03:42 AM
Hello Nizam,
Unfortunately, I didn't explored this tool in deep that time.
I used to coordinate with below guy, you may try to reach him on email, I hope he should be happy to help you on this.
Edit: <removed email id>, hope you have noted it down, just deleted it to avoid any confidential issue.
Suresh
05-10-2016 03:42 AM
Hi Suresh,
Thank you very much for sharing the mail address.
Nizam
05-10-2016 07:54 AM
We are using Phone Remote (http://www.voipintegration.com/Software/Phone-Remote/) to remote control the Phones.
You can place calls, write macros and press any button you can find on the phone.
A Trial Version is available.
Regars,
Martin
05-10-2016 06:52 PM
Nizam,
This one is free and can control the 7942:
https://www.singlewire.com/free-xml-apps.html
System Requirements: Windows 7, 2000, XP or Vista
Cisco IP Phone Models: 6921, 6941, 6945, 6961, 7911, 7921, 7925, 7926, 7931, 7937, 7940, 7941, 7942, 7945, 7960, 7961, 7962, 7965, 7970, 7971, 7975, 8961, 9951, 9971
Please rate helpful content (i.e. videos, documents, comments) so quality content shows at the top of people's search results. Also, please select the correct answer(s) if any comment(s) answers your question otherwise the question remains on the support forums as unanswered.
12-10-2017 08:08 AM
02-07-2018 10:10 AM
Tried PRCUT tool. Works OK. You can view screen on one phone or emulate button push on multiple phones at the same time. Can be useful for ITL file deletion or background image update. Would be good if they'd offer a lab version of it.
