Remote Presence
igo.gunawan
I have CME version 10.5, and combination of SIP & SCCP phones.
This is about remote presence using BLF speed dial.
- SIP phone (8851) on site A can view SCCP ephone dn on the same site -> OK
- The same SIP phone on site A can't view SCCP ephone (number 201) on site B -> ???
- SCCP phone (8945) on site A can view the same SCCP ephone dn (number 201) on site B -> OK
Strangely, when I first configured the remote presence, it worked perfectly. But now it's suddenly broken, have restarted the CME on both sites, didn't solve it.
Can somebody with remote presence experience help?
Thank you.
Dennis Mink
Igo,
according to the CME admin guide, the following applies, between trunk connected phones.
what are you using to tie the two locations A and B together.?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmepres.html
Restrictions for Presence Service
  • Presence features such as Busy Lamp Field (BLF) notification are supported for SIP trunks only; these features are not supported on H.323 trunks.
  • Presence requires that SIP phones are configured with a directory number (using dn keyword in number command); direct line numbers are not supported.
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
Thanks for the information.
The 2 locations are connected using VPN (SIP trunk).
Given the fact that using BLF speed dial, SCCP phone (8945) on site A can view SCCP phone (8945) on site B, I think the SIP trunk has been configured correctly, please correct me if I'm wrong.
But SIP phone (8851) on site A can't view the same SCCP phone on site B.
What configuration can cause this?
Thanks.
Please see below the related config on CME site A.
voice service voip
ip address trusted list
ipv4 118.82.32.132
ipv4 10.1.100.250
ipv4 10.2.2.253
ipv4 10.2.100.253 ---------------------------------------------> (CME on site B)
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service sip refer
redirect ip2ip
fax protocol pass-through g711ulaw
sip
registrar server expires max 600 min 60
no update-callerid
early-offer forced
midcall-signaling passthru
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice register pool-type 8851
xml-config maxNumCalls 6
xml-config busyTrigger 6
num-lines 77
description Cisco IP Phone 8851
reference-pooltype 9951
voice register global
mode cme
source-address 10.1.100.254 port 5060
max-dn 20
max-pool 10
load 8851 sip88xx.11-5-1-18
authenticate register
authenticate realm all
timezone 43
voicemail 810
tftp-path flash:
create profile sync 0574892224431424
conference hardware
video
voice register dn 3
number 103
allow watch
pickup-group 100
mwi
voice register dn 5
number 111
call-forward b2bua busy 810
call-forward b2bua noan 810 timeout 3
name AH Voicemail
label AH Voicemail
mwi
voice register dn 16
number 153
allow watch
pickup-group 100
label Main Incoming
mwi
voice register pool 3
fastdial 1 00497779558 name
fastdial 2 00497779394 name
fastdial 3 00497779499 name
fastdial 4 097917499 name
id mac 0038.DFB4.4AB2
feature-button 1 DnD
type 8851
number 1 dn 3
number 2 dn 5
number 3 dn 16
dtmf-relay sip-notify
username 103 password 103
codec g711ulaw
video
blf-speed-dial 1 101 label "xx" device
blf-speed-dial 2 201 label "xxx" device -----------> 201 is the ephone dn on remote CME (site B). It's not working, I can't see the "SUBSCRIBE" message sent in debug ccsip messages.
dial-peer voice 100 voip
destination-pattern ^20[12]$
session protocol sipv2
session target ipv4:10.2.100.253 --------------------------> CME on site B
voice-class codec 1
voice-class sip options-keepalive
dtmf-relay rtp-nte
no vad
dial-peer voice 200 pots
translation-profile outgoing TELSTRA-ISDN-OUTBOUND-EXTN
preference 1
destination-pattern 2..$
port 0/0/0
no sip-register
dial-peer voice 201 pots
preference 2
port 0/0/1
no sip-register
presence
presence call-list
server 10.2.100.253 ----------------------------------------> CME on site B
max-subscription 120
watcher all
allow subscribe
sip-ua
mwi-server ipv4:10.1.100.250 expires 3600 port 5060 transport udp
presence enable
gatekeeper
shutdown
telephony-service
sdspfarm units 4
sdspfarm tag 1 hwconf
sdspfarm tag 2 xcoder
conference hardware
video
no auto-reg-ephone
max-ephones 10
max-dn 20 no-reg both
ip source-address 10.1.100.254 port 2000 strict-match
calling-number initiator
service phone videoCapability 1
service phone webAccess 0
service phone g722CodecSupport 2
service phone backlightOnTime 08:30
service phone backlightOnDuration 08:30
service phone backlightIdleTimeout 01:00
service phone homeScreen 1
service phone displayOnWhenIncomingCall 1
service phone displayIdleTimeout 01:00
service phone displayOnDuration 08:30
service phone displayOnTime 08:30
service phone daysBacklightNotActive 1,7
service phone daysDisplayNotActive 1,7
service phone ehookenable 1
service phone spanToPCPort 0
service directed-pickup gpickup
service dnis overlay
service dnis dir-lookup
service dss
system message Your current options
cnf-file perphone
load 8945 SCCP894x.9-4-2SR2-2
time-zone 43
time-format 24
date-format dd-mm-yy
voicemail 810
max-conferences 4 gain -6
call-park system application
call-forward pattern .T
call-forward system redirecting-expanded
multicast moh 239.1.1.1 port 16384
web admin system name administrator password admin
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 0.T
transfer-pattern .T
secondary-dialtone 0
night-service day Sun 08:00 07:59
night-service day Mon 17:00 07:59
night-service day Tue 17:00 07:59
night-service day Wed 17:00 07:59
night-service day Thu 17:00 07:59
night-service day Fri 17:00 07:59
night-service day Sat 08:00 07:59
night-service date Dec 25 00:00 23:59
night-service date Dec 26 00:00 23:59
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 4 dual-line
number 104 no-reg primary
description 104
allow watch
mwi sip
ephone-dn 19
number 3333
park-slot timeout 60 limit 2 recall
allow watch
ephone 4
video
mac-address 58AC.784D.5726
max-calls-per-button 3
busy-trigger-per-button 2
blf-speed-dial 1 3333 label "Call-Park"
speed-dial 1 00497779558 label
type 8945
button 1:4
rdyfce-rock-ro01#sh presence subscription summary
Presence Active Subscription Records Summary: 4 subscription
D indicate as device-based blf-speed-dial monitoring
Watcher Presentity SubID Expires SibID Status
201@10.2.100.253 3333@10.1.1.254 96 3600 0 idle
104@10.1.100.21 3333@10.1.100.254 118 3600 0 idle
102@10.1.100.24 3333@10.1.100.254 120 3600 0 idle
101@10.1.100.31 101@10.1.100.254 134 3600 0 idle
I can't get SIP phone (voice register pool 3) on CME site A to watch ephone dn 201 on CME site B.
While, this is working:
- SCCP phone (ephone 4) on CME site A can watch ephone dn 201 on CME site B.
- SCCP phone on CME site B can watch ephone dn 3333 on CME site A
Any idea?
Thanks.
