Remote VPN phone feature via Palo Alto firewall
kdamisch
Customer currently has some 7900 series phones using the certificate-based remote VPN feature through their ASA firewall. They have some new Palo Alto firewalls and would like to know if they can get these phones to register from the users' home networks through the Palo Alto firewalls to CUCM so they can decommission the ASAs. My initial response would be no, but checking to see if anyone has any thoughts on this. We can't do MRA via the Expressways since they don't have the newer supported phone models.
5 Replies 5
Jaime Valencia
All the config guides only discuss ASA, I doubt that would work, and be a supported scenario.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/11_0_1/secugd/CUCM_BK_C1A78C1D_00_cucm-security-guide-1101/CUCM_BK_C1A78C1D_00_cucm-security-guide-1101_chapter_010010.html
java
if this helps, please rate
Dennis Mink
you would definitely need to pilot this. If you are going to deploy this you have two vendors pointing at each other when you run into issues, so to me this is a case of 'first see then believe". I work with PA's and Cisco UC, and I can honesty say, interoperability between these two leave a lot to be desired.
Please remember to rate useful posts, by clicking on the stars below.
Tristan Cober
Fair warning, I've had more times I can count than fingers/toes where application overrides were needed on the PA Firewall to get traffic to traverse it correctly.
jmaires21
I am having the same issue.  I was wondering if you were able to succesfully make it work with Palo Alto?.
regards,
Juan
Jmaires & kdamisch,
Were you able to successfully get the phones to register. Im am facing an issue with our  Voice engineer  trying to get Cisco phones to successfully install a vpn certificate and fails all the time.  I did face one issue already with Palo Alto's requiring an app override policy for tcp 5061 due to phone disconnects.
