Replication fails between servers : CUCM 7.1.5.20000-6
Driss BENATTOU
Level 4
Level 4
I had 7 CUCM servers on my cluster. dprelication fails between those servers.
I stop dbreplication on all subscribers and after that the publisher and i reset for all from pub and no change.
When i issue the "utils dbreplication runtimestate", the status hungs on value 0 for subscribers and value 3 on publisher with Setup requested / completd / in Progress message displayed in front of each subscriber server.
I repeated for many times to reset replication but it made ne sense.
Thanks and Best Regards
Driss
gagansi
Please go through the below mentioned link
https://supportforums.cisco.com/docs/DOC-13672
/Gagan
Please Rate useful Posts.
gagansi
/Gagan
Can you pull the CM Database Status from Unified Reporting?
or Open a TAC Case!
Problem is resolved.
Below are the steps followed :
  • utilis dbreplication stop (all subscribers)
  • utils dbreplication stop (publisher)
  • utils dbreplication reset (publisher)
  • restart publisher (until all services are started)
  • restart subscribers (one by one --->  mandatory until all sevices are started)
  • check by doing utils dbreplication runtimestate and get value 2 on replicate counter.
Driss
