Report on MTP use
Gordon Ross
Level 9
Level 9
Is there a way to report on MTP usage, either per call (i.e. what MTP was used) or how much each MTP is used (i.e. am I out of DSP resource)
I'm on CUCM 12.5
Thank you.
Gordon.
Please rate all helpful posts.
Jaime Valencia
You'd need to use RTMT to see that real-time, there are no reports, aside from that, you'd get alerts of MTP out of resources also on RTMT.
java
if this helps, please rate
