Reset Application Password on CUCM
msaeedi
i have CUCM 10.5.1 and i need to reset web password on that call manager , i know the command to do that :
utils reset_application_administrator_ui_password , but im afraid if i apply it on the call manger and i cant login again , how i will change it successfully, any parameters needs to be checked ?
for those who tried to change , please share your experience on changing web password.
thanks & Regrads
Senior Network Engineer
Deepak Rawat
The only possibility wherein you will not be able to login again after using the utils reset_application_administrator_ui_password command will happen in below two scenarios:
1) You are not entering the correct password that you set as a result of using above command
2) The combination of username and password is not correct, in that case feel free to reset the username as well using below command:
utils reset_application_administrator_ui_name
Hence feel free to reset the password using utils reset_application_administrator_ui_password command without any doubts in mind
Deepak
- Rate Helpful Posts -
Deepak Rawat
Deepak
thanks a lot it works fine on Cisco unity connection , and i think it will work well with CUCM.
Ayodeji Okanlawon
You may be over thinking it. There is nothing to check. Just change it and if you cant login, reset it again from the CLI.
Please rate all useful posts
