Reset Voicemail Pin
eklitzkie1
I just need to reset the voicemail PIN for a user that forgot their PIN. Our phone tech is on vacation so I'm not quite sure how to get this reset.
Cisco IP Phone 7945
Eric
Do you know the IP of your CUC server and the admin credentials to login??
If you don't have that information, you cannot do this.
If you have PCA enabled, the user can do this himself.
java
if this helps, please rate
14 Replies 14
Suresh Hudda
What voicemail system you have, Cisco unity connection or Cisco unity express ?
Suresh
Unity Connection
java
I do not have this information, nor do we have PCA enabled. I'll have to wait until our phone tech gets back.
Thank you!
Go to https://syrunitypub.kiltz.com/cuadmin/home.do
login with your credentials
look for the user to want to change the pin
click on the user
hit edit on top
cahnge password.
That will change the voicemail passowrd.
For Cisco unity connection see the procedure on below link..almost it is same for unity express .
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-connection-version-80/113327-change-unity-pin-connection.html
Suresh
Could you please point me to the download/installer for the Unity Connection Program.
Do you mean install/upgrade page, if yes..
Procedure
Step 1 Browse to the URL for Cisco Unity Connection Administration.
Step 2 From the Navigation menu in the upper, right corner of the Cisco Unity Connection Administration window, choose Cisco Unified OS Administration and click Go.
The Cisco Unified Communications Operating System Administration Logon window displays.
Note You can also access Cisco Unified Communications Operating System Administration directly by entering the following URL:
http://server-name/cmplatform
Suresh
Don't forget to mark this discussion as "Answered" if it's been answered :-)
Suresh
The URL provided doesn't work.
Are u able to open CUC admin page ? Suresh
Forget pin to retrieve voicemail.
fearknotma
trying to find info on how to reset the pin
Likely you’d have a much better chance to get help if you’d create your own post instead of asking your question on a +4 years old post, that is also marked as answered.
Response Signature
