Restrict calls to a particular number cme
shiblyibrahim
Level 3
Level 3
How can I block an outgoing call to a number like 118118 or if users dial 9 118118.
I have tried all the alternatives with translation reject, no port number in the dial-peer but still the call seems to go out.
Please rate the post Shibly Ibrahim
Hi Mohamed.
To achieve this you can use cor list.
Have have a look to this doc
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Carlo
Please rate all helpful posts
Please rate all helpful posts "The more you help the more you learn"
Carlo,
Any other alternative. Since I dont want to use COR at the moment
You can use after-hours block pattern under telephony-service.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html#wp1022333
Hope to help, please remember to rate if it does.
Kind regards,
- Adrian.
nirmalissac
Refer
https://supportforums.cisco.com/thread/2020843
instead of incoming translation profile as depicted here, use outgoing
