Restrict conference for some phones/extensions
juan.hinojosa89
I want to know if there is a way to restrict some phones/extensions to make ad hoc conferences. We want that only some phones/extensionos be able to make ad hoc conferences, the other ones do not.
Thank you
7 Replies 7
Jaime Valencia
Yes, adjust the MRG and MRGL as necessary.
java
if this helps, please rate
Hi Jaime
We did! We left the mrgl field to <none> from the device pool and from the phone also as <none> and it is still able to do conferences ):
Because any media resource that is NOT included in a MRG, goes to the default MRG/MRGL which is the <none> option, just as with CSSs and partitions.
EDIT: OR, it could also be getting the resources from the DP
java
I already create an MRGL only with an annunciator and the moh resources. I assigned that MRGL to the DP and to the phones configuration page also. All the phones involved in the conference were configured with the DP where is the MRGL with only the annunciator and the moh resources, and it still be able to make conferences ):
Pretty sure you still have CFB in the default MRG/MRGL, look at the traces and you can confirm that.
You'll see clearly where they're pulling resources from in the traces.
java
I will do that, thanks Jaime
create a dud CFB and add that to the MRG of the phone that is not supposed to used ad hoc, so you avoid defaults
Please remember to rate useful posts, by clicking on the stars below.
