Restrict settings access on Cisco Phones
Dominic Ellis
I want to change the Setting Access on devices to Restricted from Enabled.
This is for several thousand phones so I want to do a bulk update.
I am using Call Manager 7.1.5
The Phone configurations are set also to use Standard Common Phone Profiles.
I presumed that if I updated the Setting Access within the Standard Common Phone
Profile to Restricted then the phones would be updated.
This doesn't happen and I can't see another way of updating in bulk, there doesn't seem
to be any available options in BAT also.
Any help gratefully received.
Dominic
2 Accepted Solutions
Hi Dominic,
I just tested this out and it worked fine.  When you select your phones as a test, try selecting a single phone (ex. a 7961) and see if the setting appears.  I tested this with a batch of 7961's and worked fine.  When I grouped together phones such as 7961's with CIPCs, CUPC's, etc the setting disappeared.
HTH,
Chris
Dominic
You need to use BAT as above but select the phones by type - Settings then appear
5 Replies 5
clileikis
Level 7
Level 7
Hi Dominic,
In CUCM try:  Bulk Administration > Phones > Update Phones > Query > Select Phones > Settings Access > Select Enabled.
HTH,
Chris
Hi Chris,
Thanks for your reply - unfortunately there is no setting access available in the list of options.
Dominic
Hi Dominic,
HTH,
Chris
Dominic
Thanks for the replies - works ok now - choosing by device type - worth noting that ip communicator
only seems to allow enabled or disabled - not restricted.
Have updated your post scores accordingly.
Cheers
Dominic
