Return 5XX cause code on CUBE or CUCM to services provider.
KY_
Level 4
Level 4
Hi Dear,
I want to response spesific cause code on my CUBE or CUCM to services provider.Is there a any way do this.
For example; if call comes from services provider to me 212444555  on  my CUBE , i want to response  them 5XX cause code.
Rajkumar Yadav
Level 4
Level 4
You can refer the blow link for rejecting the call with voice translation rules and profiles.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html
Inbound Dial Peer
dial-peer voice <num> [pots|voip|vofr|voatm]
translation-profile [incoming | outgoing] <name>
For Blocking Calls
dial-peer voice <num> [pots|voip]
call-block translation-profile incoming <name>
call-block disconnect-cause incoming <cause>
carrier-id source <name>
here the cause options mentioned are
  • Invalid-Number
  • Unassigned-number
  • User-Busy
  • Call-Rejected
Raaj
Hi Rajkumar,
I know this one but its not covers my picture because i need to return only 5XX cuase code not different.
Especialy  ı want to return 503 services unavailable.
