Expansion module 7915
moussa.malqui1
Hi All,
I have 2 questions about expansion module 7915. the first is how i can active the screen light? the second is : the expansion module 7915 can get the power by PoE from IP Phone?
thanks in advance
5 Replies 5
you have to supply power to the side card through a power cube and connect it up  with an AUX lead to the main phone.Check overview section here for the compatibility and here is a good thread about configuration
***Please rate all the useful posts***
-Prabath
Hi Preranda,
So we can't supply it directely from IP Phone by PoE (AUX Lead)?
sorry just noticed your reply,unfortunately no
-Prabath
Hi Maussa,
To make is simpler:
1 IP phone  with POE + 1 7915 module = need power adapter
1 IP phone  with local power + 1 7915 module =no additional power cube.
1 IP phone  with POE or local + 2 7915 module = Definitely need power cube
~Amit
Please rate if helpful.
Manish Gogna
Hi Moussa,
As per the datasheet of 7915
Table 7. Power Requirements
Number of Cisco Unified IP Phone Expansion Module 7915 Modules
Cisco Unified IP Phone 7962G, 7965G, and 7975G Models Power Source
Items to Order
In-line
1 Cisco Unified IP Phone Expansion Module 7915
1 single footstand
1 power cube
1 country cord
Local power (cube) *
1 single footstand
In-line or local **
2 Cisco Unified IP Phone Expansion Module 7915s
1 double footstand
1 power cube
1 country cord
* A single Cisco Unified IP Phone Expansion Module 7915 can receive power from a locally powered Cisco Unified IP phone.
** Local power must be connected to the first Cisco Unified IP Phone Expansion Module 7915 to supply power to both Cisco Unified IP Phone Expansion Module 7915 modules.
Manish
