11-12-2012 10:16 PM - edited 03-16-2019 02:09 PM
Hi All,
I am facing an issue in which we are routing calls to a clients CUCM who are in turn routing the calls to a GSM gateway.
Now when i dial from Phone A to Phone B No ringback is heard. I have tried the progress_ind commands but i feel i myt be applting it on the wrong router.
Is there anyway we can force the orignating router to play the ring back without making changes to the rest of the network?
Hassan
11-13-2012 04:29 AM
Can you try in the CME dial-peer
tone ringback altert-no-PI
If that doesn't work, will needed detailed traces.
11-13-2012 05:13 AM
Hi Paolo
would these debugs do ?
debug voip ccapi inout
debug h225 asn1
debug cch323 all
I will try to implement this config. But can you please tell me what this command would do? From some debugs i tool i remember the PI was coming up as Null.
Hassan
11-13-2012 05:37 AM
You can look up any command in "IOS command reference" on cisco.com.
11-20-2012 09:42 PM
11-21-2012 04:36 AM
Traces might not help at times.
Try configuring the CME to go directly to the GSM gateway for cellphone number.
