08-08-2014 11:29 PM - edited 03-16-2019 11:41 PM
hello,
if aneone have ringback tone.wav file, please send me...i want to apply for moh..
thanks
08-09-2014 02:59 AM
hello
If your have IPCC , there is a ringback wav file under "C:\program files\wfavvid\prompts\system\default"., you can get it . Then go to CUCM-media resources - Music On Hold Audio Source then upload it . Note: Make sure that the ringback.wav file is in the CallManager server and configured appropriately. Otherwise this can cause CPU spiking in Cisco CallManager
please rate all useful information
08-09-2014 03:35 AM
i have verson 9.1 cucm and uccx...
how can get it?
08-09-2014 03:40 AM
Hello
Can you check the below link , please?.You will get what r u looking for.
https://supportforums.cisco.com/discussion/11197971/uccx-music-hold
08-09-2014 03:31 AM
Go to Cisco OS administration - TFTP file management - put a filter "RingBack" with filter criteria contains. This will show you the directory in which Ringback file is stored to.
Now open command promt from your computer and put this TFTP command in it.
TFTP -i x.x.x.x get united_states/AnnRingBack.alaw.wav
where x.x.x.x is your CUCM ip and united_states is the directory. It will copy that wav file to your local drive from which you executed that command.
07-31-2018 08:25 AM
