Route list Error with H323 Gateways
frandeprado
Hi I have a CUCM 8.0.3.20000 with 2 h323 gateways, one with 3 E1 PRI and the other one with 1 E1 PRI, I have a route pattern that points first to the 3E1 gateway and then the other one.
In case that all E1s on the first gateway are full, the users are hearing "your call cannot be complete as dialed ....... "
Is This a normal behavior? can i changed this ?
Thanks a lot
William Bell
We may need more information, but on initial reaction I would recommend looking at this global common on the IOS voice gateway.
"no dial-peer outbound status-check pots"
HTH.
Bill
Please rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
HTH.
Bill
Hi William
Many thanks for your answer, i gonna test it this afternoon, i will let you know.
FD
that command and change the ios was the solution, thanks a lot.
FD
