03-10-2016 08:20 AM - edited 03-17-2019 06:11 AM
I have a ESXi CUCM working fine and another VM with Windows OS. If try to access RTMT tool always appear this issue.
I have verified that there is connection between VM- Windows OS and CUCM VM.
Best regards,
03-10-2016 09:27 AM
What are you entering as the IP address? It needs to be the IP/FQDN of the CUCM Publisher node.
03-10-2016 09:28 AM
Have you tried from some other PC??
03-10-2016 10:15 AM
I have tested with another real PC and doesn't work. And the port 8443 is opened. This issue is very strange.
Best regards,
03-10-2016 04:10 PM
Can you verify that the "Cisco CallManager Serviceability RTMT" service is started?
03-11-2016 09:42 AM
The service is working. Furthermor I have restarted and doesn't works still.
01-25-2018 08:30 AM
I experienced this very same issue with a similar setup and was able to correct it by running RTMT in compatibility mode from my Windows VM.
