Under RTMT reporter I am getting 48 critical which is a graph ,How to get the details of the error
04-25-2017 01:38 AM - edited 03-17-2019 10:08 AM
04-25-2017 01:48 AM
Download the RTMT Plugin ( From CUCM Administrator Page Application>Plugins) Install and login in the same.
You will be able to see the alert details in the Alerts Window.
Haris
Please rate and mark correct as applicable
04-28-2017 02:40 AM
The plugin can be installed on any machine ?
How to login once installed
04-28-2017 03:41 AM
It can be installed on Windows machines, you launch it and it asks for cucm ip address and the login credentials are the same as you use to login to cucm admin page.
Check this for more details for supported Windows platforms and usage
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/10_0_1/rtmt/CUCM_BK_CA30A928_00_cisco-unified-rtmt-administration-100.html
Manish
