RTP Stream Issue
Ermir Morina
Greetings,
I am having an issue with RTP Stream (I assume).
So my setup is:
ITSP->CUBE->CUCM->UCCX
This setup was working before and all of a sudden when I try calling from my mobile phone, the signaling works, the call gets connected but I get no audio whatsoever.
What would be the best way to troubleshoot this issue?
I would greatly appreciate your responses and help.
Kind regards,
Ermir.
Both Side not able to hear or just one side ? I Would start checking the  reachability  first.
Response Signature
Hi!
So the problem is that the IP Phone is on a remote office, I try calling again from my mobile phone and check the show rtp commands and this is what I get:
CUBE#show call active voice brief
<ID>: <CallID> <start>ms.<index> (<start>) +<connect> pid:<peer_id> <dir> <addr> <state>
dur hh:mm:ss tx:<packets>/<bytes> rx:<packets>/<bytes> dscp:<packets violation> media:<packets violation> audio tos:<audio tos value> video tos:<video tos value>
IP <ip>:<udp> rtt:<time>ms pl:<play>/<gap>ms lost:<lost>/<early>/<late>
delay:<last>/<min>/<max>ms <codec> <textrelay> <transcoded
media inactive detected:<y/n> media cntrl rcvd:<y/n> timestamp:<time>
long duration call detected:<y/n> long duration call duration :<sec> timestamp:<time>
LostPacketRate:<%> OutOfOrderRate:<%>
LocalUUID:<%> RemoteUUID:<%>
VRF:<%>
MODEMPASS <method> buf:<fills>/<drains> loss <overall%> <multipkt>/<corrected>
last <buf event time>s dur:<Min>/<Max>s
FR <protocol> [int dlci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
<codec> (payload size)
ATM <protocol> [int vpi/vci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
Tele <int> (callID) [channel_id] tx:<tot>/<v>/<fax>ms <codec> noise:<l> acom:<l> i/o:<l>/<l> dBm
MODEMRELAY info:<rcvd>/<sent>/<resent> xid:<rcvd>/<sent> total:<rcvd>/<sent>/<drops>
speeds(bps): local <rx>/<tx> remote <rx>/<tx>
Proxy <ip>:<audio udp>,<video udp>,<tcp0>,<tcp1>,<tcp2>,<tcp3> endpt: <type>/<manf>
bw: <req>/<act> codec: <audio>/<video>
tx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 bytes>
rx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 bytes>
Telephony call-legs: 0
SIP call-legs: 2
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
1A6F : 2135 64456250ms.1 (09:13:24.798 UTC Fri May 21 2021) +90 pid:1 Answer MYMOBILENUMBER connected
dur 00:00:20 tx:15/2400 rx:1009/161440 dscp:0 media:0 audio tos:0xB8 video tos:0x0
IP ITSP-IP:29914 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded: No ICE: Off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
LostPacketRate:0.00 OutOfOrderRate:0.00
LocalUUID:5771abefdf81595aa347bf7266aafa2e
RemoteUUID:ccaf168389280064b62077ba22180299
VRF: NA
1A6F : 2137 64456260ms.1 (09:13:24.808 UTC Fri May 21 2021) +80 pid:3 Originate 77803 connected
dur 00:00:20 tx:1009/161440 rx:15/2400 dscp:0 media:0 audio tos:0xB8 video tos:0x0
IP 10.155.2.201:25450 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded: No ICE: Off
LocalUUID:ccaf168389280064b62077ba22180299
RemoteUUID:5771abefdf81595aa347bf7266aafa2e
VRF: NA
SIP call-legs: 2
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
CUBE#show voip rtp connections detail
VoIP RTP Port Usage Information:
Max Ports Available: 8091, Ports Reserved: 101, Ports in Use: 2
Port range not configured
Min Max Ports Ports Ports
Media-Address Range Port Port Available Reserved In-use
Global Media Pool 16384 32766 8091 101 2
VoIP RTP active connections :
No. CallId dstCallId LocalRTP RmtRTP LocalIP RemoteIP MPSS VRF
1 2135 2137 16436 29914 CUBE-OUT-IP ITSP-IP NO NA
callId 2135 (dir=1): called=23290320 calling=MYMOBILENUMBER redirect= loopback=NO confID=-1 mode=2 rtp(tx:15/rx:1125) rtcp(tx:0/rx:0) MPSS NO VRF NA peer callId 2137: called=77803 calling=MYMOBILENUMBER redirect= , confID:-1
, vrf = NA 1 context 0x3A014240 xmitFunc 0x366615DC
2 2137 2135 16440 25450 CUBE-TO-CUCM-IP CUCM-IP NO NA
callId 2137 (dir=2): called=77803 calling=MYMOBILENUMBER redirect= loopback=NO confID=-1 mode=1 rtp(tx:1125/rx:15) rtcp(tx:0/rx:0) MPSS NO VRF NA peer callId 2135: called=23290320 calling=MYMOBILENUMBER redirect= , confID:-1
, vrf = NA 1 context 0x3A012D00 xmitFunc 0x366615DC
Found 2 active RTP connectionsee
callId 2135 (dir=1): called=23290320 calling=MYMOBILENUMBER redirect= loopback=NO confID=-1 mode=2 rtp(tx:15/rx:1387) rtcp(tx:0/rx:0) MPSS NO VRF NA peer callId 2137: called=77803 calling=MYMOBILENUMBER redirect= , confID:-1
callId 2137 (dir=2): called=77803 calling=MYMOBILENUMBER redirect= loopback=NO confID=-1 mode=1 rtp(tx:1387/rx:15) rtcp(tx:0/rx:0) MPSS NO VRF NA peer callId 2135: called=23290320 calling=MYMOBILENUMBER redirect= , confID:-1
So I can see the TX: on the leg to ITSP not changing and the RX: on the leg to the CUCM no changing.
