Webex Teams login process.
Bejesh Kumar V
Hi ,
Can someone explain, How is the login process of webex teams client?
Is that same as jabber?
How to create prt for webex teams...
Thanks and regards
bejesh..
AFAIk new webex app has a underlying jabber module which is same as jabber application. Webex app works with the UDS and edge SRV  discoveries. How it work, depend on how you using it.  I never took PRT  from webex app.
Response Signature
A problem report is generated by going to Help > Send Logs and then you go into Control Hub > Troubleshooting to collect the logs.
Response Signature
