safe to revert from a cucm snapshot on ucs?
baselzind
Level 6
Level 6
i discovered that my cucm is running on a snapshot , my manager assked me to delete the snap shot , the problem is im afraid if a revert all the phone and configuration of the cucm would be lost since the snapshot was created? can i make a snapshot my main vm image??? basically how can i keep the changes made to the snapshot of the cucm and delete it?
2 Accepted Solutions
Aaron Harrison
VMware 101:
'delete' a snapshot means delete that point-in-time as a place you can go back to. It will not 'go back' to the snapshot, it will leave the VM in the current state.
'revert to' snapshot goes back to the old state at the point the snapshot was taken.
So delete it, but do so during off-peak hours as it will probably cause some slowdown whilst the disk activity is high.
Also note that Cisco don't like you snapshotting UC VMs.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
It needs to be mentioned that Snapshots are not supported on CUCM as per:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
and they are known to cause many issues (performance crashes).
If you already have snapshot it needs to be removed as you've mentioned, but this needs to be done out of working hours, as I've seen the scenarios where adding removing snapshots on CUCM as causing some services to core dump, especially sensitive services like Call Manager service or CTI Manager service
Leszek
6 Replies 6
Aaron Harrison
VMware 101:
Aaron
so to double check if i press "revert to current snapshot" means i will revert the vm "cucm" to the point in time the snap shot was created? and deleting snapshot will not affect my current running vm "cucm" in any way ? if so do i need to turn off my cucm when i delete the snapshot or i can do it so while it is on?
Leszek
so you advice to shut down the cucm when i delete the snapshot?
No need to shutdown. But make sure you delete is during maintenance window.
Leszek
This is the specific doc that talks about how to check for snapshots in vSphere Client for Cisco Unified Communications (UC) applications and their impact on UC apps
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/116459-technote-product-00.html
Manish
