same PRI channel always selected!
pblower
I've got a 2801 MGCP gateway with a VWIC2-1MFT-T1/E1 configured as a PRI and using bottom-up channel selection.
All 23 channels are administratively up. The first call is successful and used channel 23.
When channel 23 is in use I can see subsequent calls come into the gateway - even saying that is will use channel 22. However, the "debug isdn q931" output shows that it actualy tries to use channel 23 and fails with:
"May 23 07:54:05.271 MDT: ISDN Se0/2/0:23 Q931: RELEASE_COMP pd = 8 callref = 0x81A7
Cause i = 0x80AC - Requested circuit/channel not available"
We are using switch type DMS-100 and the Telco confirms that is correct. My gear is the user, the telco is network.
Anyone with a suggestion as to what I should try? Changing to top-down channel selection results in no calls going through.
Thanks!
paolo bevilacqua
Hi, if you can take complete trace it would help, because you are omitting to mention if "subsequent calls" are in or out, etc.
