SCCP firmware for 7970G
skoch
I'm looking for the SCCP firmware for a 7970G.  I don't see the 7970G listed under Downloads Home / Collaboration Endpoints / IP Phones / Unified IP Phone 7900 Series.  Any idea if that firmware is still available for download somewhere?  Thanks.
Ratheesh Kumar
I don't think you can download the 7970 firmware files. Suggest you to open up a TAC.
Also there is another possibility of updating the device pack of your CUCM. The new firmwares will be installed during that.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Jaime Valencia
No, it was permanently removed from the downloads site, your only chance to get it is via TAC, or your SE / AM.
java
if this helps, please rate
