04-30-2011 11:24 PM - edited 03-16-2019 04:44 AM
Can i configure screen saver for IP phones globally on CCM??
05-01-2011 05:43 AM
Yes you can , all what you have to do is go to the enterprise parameters and add the url of the screen saver to the IDLE URL , make sure to add timer (under the IDLE url) to perform how much time should it wait until it works on the ip phone.
However there is a small problem that it will work on all phones except the 7911 (small screen) .
Amer
05-01-2011 06:20 AM
Hi Amer,
Thanks for your response.
Can I also do it for Weekends? (I would like to do it for Friday & Saturday throughout the day).
Partha
05-01-2011 09:04 AM
No , i don't think it is possible , however it may be done through the screen saver itself (code) and maybe , i am not sure but from the CUCM definility i never saw anything like this.
Amer
