second ISDN30
aaa5678
I'm trying to configure the second ISDN on the same gateway but I cannot get this working.
I would be grateful if I could have some help with the configuration? I need to send the incoming traffic for both ISDNs to the call manager. The config that i havefor the  first ISDN;
controller E1 0/0/0
 pri-group timeslots 1-24 service mgcp
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-net5
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 no cdp enable
16 Replies 16
Shadi Shami
Level 7
Level 7
What do you get when you try to configure the 2nd controller?
Thank you,
Shadi
what is the number of time slots u are configuring for second E1 PRI?
In your existing E1 PRI, are u using first  24 TS[fractional PRI]
can u share complete config?
regds,
aman
well I didn't realise that I have to configure the second E1 :\
I'm not that familiar with the ISDN, can you guys please help me with configuring the second E1?
when I try to configure the second E1, i get this:
402-3(config)#controller E1 ?
  <0-0>  Controller slot number
so how i can configure the second one/
If u have dual port E1 card , then u need to configure controller e1 0/0/1 since 0/0/0 is already configured.
regds,
aman
I dont have dual port.
402-3(config)#controller E1 0/0/?
  <0-0>  Controller port number
If u do not have second E1 port available, then u won't be able to configure.
accordingly, u need to buy one E1 port card if router has slot available or replace the existing card with Dual E1 port card.
regds,
amn
this is the output from show hardware:
Cisco CISCO2911/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FCZ183171K3
3 Gigabit Ethernet interfaces
24 Serial interfaces
5 ISDN Basic Rate interfaces
1 terminal line
1 Channelized E1/PRI port
DRAM configuration is 64 bits wide with parity enabled.
I suppose , you want to configure BRI ports but u have been referring to E1 Controller.
can u share show diag and show inventory?
regds,
aman
402-3>en
Password:
tp-7402-3#show inven
tp-7402-3#show inventory
NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FCZ183171K3, Hw Revision: 1.0"
PID: CISCO2911/K9      , VID: V07 , SN: FCZ183171K3
NAME: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-1MFT-T1/E1  , VID: V01 , SN: FOC182816N7
NAME: "2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation two port BRI voice interface daughtercard"
PID: VIC2-2BRI-NT/TE=  , VID: V  , SN: FOC08500PBH
NAME: "2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation two port BRI voice interface daughtercard"
PID: VIC2-2BRI-NT/TE   , VID: V01 , SN: FOC10442HLS
NAME: "Wan Interface Card BRI U (82912) on Slot 0 SubSlot 3", DESCR: "Wan Interface Card BRI U (82912)"
PID: HWIC-1B-U         , VID: V03 , SN: FOC19039MH2
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN: FOC18297CKB
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V05 , SN: QCS18201ZAD
402-3# show diag
Slot 0:
        C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 9 ports
        Port adapter is analyzed
        Port adapter insertion time 1w0d ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC18166KMN
        Hardware Revision        : 1.0
        Part Number              : 73-11833-12
        Top Assy. Part Number    : 800-30797-06
        Board Revision           : D0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2911/K9
        Version Identifier       : V07
        CLEI Code                : CMMJD00ARA
        Processor type           : C1
        Chassis Serial Number    : FCZ183171K3
        Chassis MAC Address      : 88f0.31ae.7288
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 38 31 36 36 4B 4D 4E 40
          0x10: 06 18 41 01 00 82 49 2E 39 0C C0 46 03 20 00 78
          0x20: 4D 06 42 44 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 31 31 2F 4B 39 89 56 30 37 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 4A 44 30 30 41 52
          0x50: 41 09 C1 C2 8B 46 43 5A 31 38 33 31 37 31 4B 33
          0x60: C3 06 88 F0 31 AE 72 88 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 25 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0235-07
        PCB Serial Number        : QCS18201ZAD
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V05
        Product (FRU) Number     : PWR-2911-AC
        CLEI Code                :
        Board Revision           : A0
          0x00: 04 FF 40 05 E5 DF 45 01 55 00 EB 07 88 00 00 00
          0x10: 00 C1 8B 51 43 53 31 38 32 30 31 5A 41 44 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 35 20 CB 8B 50 57
          0x30: 52 2D 32 39 31 31 2D 41 43 C6 8A 00 00 00 00 00
          0x40: 00 00 00 00 00 F3 00 59 41 00 C2 42 00 05 F8 00
          0x50: 50 01 F4 10 38 02 EE 13 38 03 E8 15 9B 04 E2 17
          0x60: B0 05 DC 1B 07 06 D6 1B FD 07 D0 1C CB 08 CA 1D
          0x70: 83 09 C4 1E 21 0A BE 1E 8F 0B B8 1E F8 0D AC 1F
          0x80: BC 0F A0 20 43 11 94 20 AA 13 88 21 68 17 70 21
          0x90: 68 1B 58 21 A3 1F 40 21 B2 23 28 21 AC 27 10 21
          0xA0: A6 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11577-03
        Board Revision           : D0
        Fab Version              : 03
        PCB Serial Number        : FOC18297CKB
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-32
        Version Identifier       : V01
          0x00: 04 FF 40 05 D9 41 01 00 82 49 2D 39 03 42 44 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 38 32 39
          0x20: 37 43 4B 42 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 33 32 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        Top Assy. Part Number    : 800-34657-01
        Part Number              : 73-13419-01
        Board Revision           : B0
        Fab Version              : 05
        PCB Serial Number        : FOC182816N7
        Product (FRU) Number     : VWIC3-1MFT-T1/E1
        CLEI Code                : COUIA7PCAA
        RMA History              : 00
          0x00: 04 FF 40 06 ED 41 01 00 C0 46 03 20 00 87 61 01
          0x10: 82 49 34 6B 01 42 42 30 88 00 00 00 00 02 05 C1
          0x20: 8B 46 4F 43 31 38 32 38 31 36 4E 37 89 56 30 31
          0x30: 20 CB 90 56 57 49 43 33 2D 31 4D 46 54 2D 54 31
          0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 50 43 41 41 03
          0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
        WIC Slot 1:
        VIC2 - BRI-NT/TE Voice daughter card (2 port)
        Hardware Revision        : 1.1
        Top Assy. Part Number    : 800-21861-01
        Board Revision           : B0
        Deviation Number         : 0-0
        Fab Version              : 01
        PCB Serial Number        : FOC08500PBH
        RMA History              : 00
        Product (FRU) Number     : VIC2-2BRI-NT/TE=
          0x00: 04 FF 40 00 51 41 01 01 C0 46 03 20 00 55 65 01
          0x10: 42 42 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 30
          0x20: 38 35 30 30 50 42 48 03 00 81 00 00 00 00 04 00
          0x30: 89 56 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 2:
        Top Assy. Part Number    : 800-21861-02
        Board Revision           : A0
        Fab Version              : 01
        PCB Serial Number        : FOC10442HLS
        RMA History              : 00
        CLEI Code                : CNUIAPSAAA
          0x00: 04 FF 40 00 51 41 01 01 C0 46 03 20 00 55 65 02
          0x10: 42 41 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 31
          0x20: 30 34 34 32 48 4C 53 03 00 81 00 00 00 00 04 00
          0x30: CB 8F 56 49 43 32 2D 32 42 52 49 2D 4E 54 2F 54
          0x40: 45 89 56 30 31 20 C6 8A 43 4E 55 49 41 50 53 41
          0x50: 41 41 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 3:
        BRI U - 82912 WAN daughter card
        Top Assy. Part Number    : 800-33017-02
        Board Revision           : A0
        Fab Version              : 04
        PCB Serial Number        : FOC19039MH2
        RMA History              : 00
        Product (FRU) Number     : HWIC-1B-U
        Version Identifier       : V03
        CLEI Code                : COUIALACAC
        Part Number              : 73-12755-02
        Fab Part Number          : 28-7707-04
          0x00: 04 FF 40 05 3D 41 01 00 C0 46 03 20 00 80 F9 02
          0x10: 42 41 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 39 30 33 39 4D 48 32 03 00 81 00 00 00 00 04 00
          0x30: CB 89 48 57 49 43 2D 31 42 2D 55 89 56 30 33 20
          0x40: D9 02 40 C1 C6 8A 43 4F 55 49 41 4C 41 43 41 43
          0x50: 82 49 31 D3 02 85 1C 1E 1B 04 FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
u are using BRI voice cards[ VIC2-2BRI-NT/TE].
you need to configure BRI instead of E1 PRI.
please refer the link
http://www.cisco.com/c/en/us/support/docs/voice/digital-ccs/15415-bri-voice-port-cfg.html
regds,
aman
I'm trying to configure the BRI. The BRI that I need to configure is BRI0/3/0, But when I want to configure the voice-port it says 0/3/0 is invalid.
It has to be bri0/1/0 or bri0/2/0 .
you are trying to configure for  HWIC-1B-U which is used for WAN connectivity.
regds,
aman
these ports already got configured. still I cannot see any traffic for the new ISDN :/
maybe I bought the wrong card? I have got HWIC-1B-U in order to connect the second ISDN to the router.
