T 38 Outbound Fax Problem (bearer capability not implemented (65) )
Fikri FIRAT
Level 5
Level 5
Hi all,
We don't have any issues with inbound fax transfer but when the client tries to send a document to an outbound number, right after the receiver hears the fax tone, the call drops. We use SIP trunk. We see the following debug messages :
192C : 730 412070610ms.616 +7560 +13420 pid:75 Answer no_from_info
dur 00:00:05 tx:1/160 rx:295/46702 41  (bearer capability not implemented (65))
IP 10.145.2.145:56858 SRTP: off rtt:3312ms pl:2460/0ms lost:0/1/0 delay:65/65/75ms g711ulaw TextRelay: off
  media inactive detected:n media contrl rcvd:n/a timestamp:n/a
  long duration call detected:n long dur callduration :n/a timestamp:n/a
192C : 731 412070700ms.617 +7470 +13420 pid:12 Originate 002124784075
dur 00:00:05 tx:292/49056 rx:353/56480 41  (bearer capability not implemented (65))
Telephony 7/0:D (731) [7/0.1] tx:13320/7130/0ms g711ulaw noise:-84dBm acom:6dBm
Hi Guys,
I found this defect: CSCsi10343
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsi10343
T.38 negot fails if two m lines are sent in the offer from 3rd part serv.
Hope this helps
Jorge Armijo
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
15 Replies 15
paolo bevilacqua
Take the complete SIP trace.
Complete SIP trace is attached.
This appears to be the problem:
Nov 29 14:12:09.993: //772/CEDD229087B6/SIP/Info/sipSPIValidateConnectionAddress: dead stream since destination port is 0 for the m-line : 2
Nov 29 14:12:09.993: //772/CEDD229087B6/SIP/Error/sipSPIDoMediaNegotiation:
no valid fax or audio streams
Nov 29 14:12:09.993: //772/CEDD229087B6/SIP/Error/ccsip_api_response_answer: Media Negotiation failure in 200 OK
Nov 29 14:12:09.993: //772/CEDD229087B6/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:65, category:278
Which exact IOS are you using ? Do you have "voip rtp send-recv" ? This latter actually may not be need, just a wild guess.
Thanks a lot
simply remove pcma and leave pcmu on rightfax is resolved the issue.
Rgds
Rajesh
In the logs there are a few things that I see
1. I do not see the negotiation between the SIP gateway and your ITSP provider. When the CUBE receives and invite from the dialogic, It has to send an outbound invite to the provider....If you are using a sip dial-peer then we must see this
2. The audio part of the call didnt agree on any particular codec for the call. The Audio logic sends and invite with
Invite received from dialogic
Received:
INVITE sip:06576150@10.112.45.80 SIP/2.0
From: 3352959 <3352959>;tag=8af2e40-8882720a-13c4-55013-f333-79206b09-f333
To: <06576150>
Call-ID: 827c098-8882720a-13c4-55013-f333-442e35b3-f333
CSeq: 1 INVITE
Via: SIP/2.0/UDP 10.114.130.136:5060;branch=z9hG4bK-f333-3b6023f-4726b75e
Contact: <10.114.130.136:5060>
Max-Forwards: 70
User-Agent: Brktsip/6.5.2B5 (Dialogic)
Content-Type: application/sdp
Content-Length: 224
v=0
o=- 2209052474 0762116000 IN IP4 10.114.130.136
s=no_session_name
t=0 0
m=audio 56088 RTP/AVP 0----------codec g711ulaw advertised
c=IN IP4 10.114.130.136
a=rtpmap:0 pcmu/8000
m=audio 56088 RTP/AVP 8---------codec g711alaw advertised
a=rtpmap:8 pcma/8000
By the time the CUBE sends a 200 okay back to dialogic..it just advertises the same set of codecs.
ent:
SIP/2.0 200 OK
To: <06576150>;tag=18FD75F4-5FB
Date: Thu, 29 Nov 2012 12:11:58 GMT
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Remote-Party-ID: <6576150>;party=called;screen=no;privacy=off
Contact: <06576150>
Supported: replaces
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Supported: timer
Content-Disposition: session;handling=required
Content-Length: 245
v=0
o=CiscoSystemsSIP-GW-UserAgent 5073 2568 IN IP4 10.112.45.80
s=SIP Call
c=IN IP4 10.112.45.80
t=0 0
m=audio 20044 RTP/AVP 0
a=rtpmap:0 PCMU/8000
m=audio 0 RTP/AVP 8
a=rtpmap:8 PCMA/8000
Under normal circumstances, th CUBE should respond with the codec noegotiated with the provider. either g711u or g711a. So we need to see whats happening on the leg of your ITSP..This is not normal..and thats why we see two media streams for a single call..
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
The following is what I suspected :
Nov 29 14:11:58.521: //772/CEDD229087B6/SIP/Error/sipSPISearchForForkingCodec: Non-conforming codec (g711alaw) in stream 2; the stream will be rejected.
Nov 29 14:11:58.521: //772/CEDD229087B6/SIP/Error/sipSPICheckForkedStreamCriteria: Invalid mainStream (g711ulaw) forking (g711alaw) codec combination
So it appears there's a mismatch between the two legs, so how to fix this?
Hi Guys,
Hope this helps
Jorge Armijo
Jorge, +5
I though that the m-line looks a bit strange..Never seen two m lines been sent before. Good find for us.
The work around is as follows: You  need to configure dialogic to send only one codec.
Symptom:
Fax calls from right fax fail using T38. Call tears down right after the T38 negotiation completes.
Conditions:
Rightfax sends 2 M lines in SDP.
Workaround:
Configure right fax to use only 1 codec. If configured for both PCMU and PCMA (g711ulaw and g711alaw) it will send 2 M lines (incorrectly).
Generic steps for changing rightfax:
In the configuration tool, in advanced mode, highlight the IP call control stack that you are using in the left pane, ( SIP or H323 )
Click on RTP parameters in the right pane, there is a drop down for the RTP
codec list. simply remove pcma and leave pcmu.
make sure that there is no spaces after pcmu.
Save and then apply. SDP offering after this should only reflect pcmu offering.
Symptom:Fax calls from right fax fail using T38. Call tears down right after the T38 negotiation completes.
Conditions:
Workaround:
First of all, thanks for quick and helpful replies, but still the problem exists.
The IOS version is "Cisco IOS Software, 5400 Software  Version 15.1(2)T4"
We changed the config so that the router would use only one codec but still we can't send outbound fax, here is some relevant configurations from the gateway :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 5 hs-redundancy 2 fallback none
no fax-relay sg3-to-g3
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class codec 99
rule 1 /^.*\(3352950$\)$/ /2950/
rule 2 /^.*\(3352951$\)$/ /2951/
rule 3 /^.*\(3352952$\)$/ /3002/
voice translation-rule 2
rule 1 /^90212/ /0/
rule 2 /^90/ /00/
rule 3 /\(^[2-8]......$\)/ /00212\1/
rule 4 /^/ /0/
voice translation-rule 3
rule 1 /^3001$/ /2123352950/
rule 2 /^3002$/ /2123352951/
voice translation-rule 10
rule 1 /^$/ /2123352959/
voice translation-profile CIKIS
translate calling 3
voice translation-profile FAX
translate calling 10
dial-peer voice 12 pots
trunkgroup PRI
translation-profile incoming PRI
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
incoming called-number .
direct-inward-dial
dial-peer voice 75 voip
translation-profile outgoing FAX
huntstop
destination-pattern 3352959
session protocol sipv2
session target ipv4:10.114.130.136
session transport udp
voice-class codec 99
fax-relay ecm disable
fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback none
This config does not show the dial-peer pointing to your sip provider. Why not send the full config.
Please send the full config.
Do another test call and send only
debug ccsip messages.
Full configuration and "debug ccip messages" output is attached.
The Dialogic device is still sending tow m lines...Please cnfigure only to use one codec.
v=0
o=- 2209058953 0052419000 IN IP4 10.114.130.136
s=no_session_name
t=0 0
m=audio 56160 RTP/AVP 0
m=audio 56160 RTP/AVP 8
I can see also that this call is not going over a SIP trunk...
The called fax number is 06576150
The dial-peer that is matched is this
trunkgroup PRI
direct-inward-dial
So its not going over the sip trunk..Just to let you know
Hi all,
After the codecs are changed in the location's config, the issue has been resolved, we really appreciate your help very much, thank you all, have a nice day!
Fikri
