Second secure SIP trunk between CUBE and Internet service provider .
W-Sardar
Hi Team,
We are in the process of testing and implementing a secure SIP trunk between our CUBE and the Internet Service Provider. While we already have an existing SIP connection with the ISP, this new connection will be established over the internet.
We have installed the SSL certificate and would like guidance on how to configure the secure SIP trunk and apply the certificate without impacting the current SIP connection.
Could you please share a simple configuration example or format for this setup?
5 Replies 5
is "sip trunk line" from ISP has authentication on it ?
(Rate by "Helpful" or "Accept") (محمدرضا هادی_ایران) (Email: morez.hadi@gmail.com)
Yes ,the new sip line will Include encryption and SIP digest authentication as standard .
It is just a matter of configuring a second set of dial peers, inbound and outbound, and set these up to use secure communication. There isn't much more to it.
Response Signature
Please find the attached current configuration. Could you please share a simple configuration example or format?
Looks like your using BT as the ITSP and if I understood you correctly you're looking at adding their SIP trunk service over internet, aka SOTI. We happen to have the exact same setup, so instead of trying to make modifications to your shared config I took the easy way out by copying the parts of config from one of our SBCs that pertains to this and obfuscate any sensitive information.
voice service voip
 address-hiding
 sip
  sip-profiles inbound
voice class uri CUCM sip
 host ipv4:10.xx.xx.y1
 host ipv4:10.xx.xx.y2
voice class uri PSTNSOTI sip
 host ipv4:10.xx.xx.1
voice class uri PSTNGSIP sip
 host ipv4:10.xx.xx.2
voice class sip-profiles 10
 rule 10 request ANY sip-header From modify "<internal interface IP>" "<external interface 1 IP>"
 rule 20 request ANY sip-header From modify "<external interface 1 IP>" "<public internet IP>"
 rule 30 request ANY sip-header Remote-Party-ID modify "Remote-Party-ID:(.*)(<sip:.*@.*>)" "Remote-Party-ID: \2"
 rule 40 response ANY sip-header Remote-Party-ID modify "Remote-Party-ID:(.*)(<sip:.*@.*>)" "Remote-Party-ID: \2"
 rule 50 request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)(<sip:).*@.*(>)" "P-Asserted-Identity: \2+<main circuit number>@<public internet IP>\3"
 rule 60 response ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)(<sip:).*@.*(>)" "P-Asserted-Identity: \2+<main circuit number>@<public internet IP>\3"
 rule 70 request ANY sip-header Contact modify "(<.*)@<external interface 1 IP>:(.*)>" "\1@<public internet IP>:\2>"
 rule 80 response ANY sip-header Contact modify "(<.*)@<external interface 1 IP>:(.*)>" "\1@<public internet IP>:\2>"
 rule 90 request ANY sip-header Via modify "(SIP.*) <external interface 1 IP>(.*)" "\1 <public internet IP>\2"
 rule 100 request INVITE sip-header Requested-By modify "(.*:)<external interface 1 IP>>" "\1<public internet IP>>"
 rule 110 request ANY sdp-header Session-Owner modify "<external interface 1 IP>" "<public internet IP>"
 rule 120 response ANY sdp-header Session-Owner modify "<external interface 1 IP>" "<public internet IP>"
 rule 130 request ANY sdp-header Connection-Info modify "<external interface 1 IP>" "<public internet IP>"
 rule 140 response ANY sdp-header Connection-Info modify "<external interface 1 IP>" "<public internet IP>"
 rule 150 request ANY sdp-header Audio-Connection-Info modify "<external interface 1 IP>" "<public internet IP>"
 rule 160 response ANY sdp-header Audio-Connection-Info modify "<external interface 1 IP>" "<public internet IP>"
 rule 170 request INVITE sip-header Diversion modify "Diversion:(.*)(<sip:).*@.*(>)" "Diversion: \2+<main circuit number>@<public internet IP>\3"
voice class sip-profiles 20
 rule 10 request ANY sip-header From modify "<internal IP>" "<external interface 1 IP>"
 rule 50 request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)(<sip:).*(@.*>)" "P-Asserted-Identity: \2+<main circuit number>\3"
 rule 60 response ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)(<sip:).*(@.*>)" "P-Asserted-Identity: \2+<main circuit number>\3"
 rule 170 request INVITE sip-header Diversion remove
voice class sip-profiles 100
 rule 10 request ANY sip-header From modify "<public internet IP>" "<external interface 1 IP>"
 rule 20 request OPTIONS sip-header SIP-Req-URI modify "<public internet IP>" "<external interface 1 IP>"
 rule 30 request ANY sip-header To modify "<public internet IP>" "<external interface 1 IP>"
voice class sip-profiles 200
 rule 10 request ANY sip-header Via modify "(SIP.*) <external interface 1 IP>(.*)" "\1 <public internet IP>\2"
 rule 20 request OPTIONS sip-header From modify "(<.*):<external interface 1 IP>" "\1:<public internet IP>"
 rule 30 request ANY sip-header To modify "(<.*):<external interface 1 IP>" "\1:<public internet IP>"
 rule 40 request OPTIONS sip-header Contact modify "(<.*):<external interface 1 IP>" "\1:<public internet IP>"
 rule 50 response ANY sdp-header Connection-Info modify "<external interface 1 IP>" "<public internet IP>"
 rule 60 response ANY sdp-header Audio-Connection-Info modify "<external interface 1 IP>" "<public internet IP>"
voice class sip-profiles 11
 rule 10 request ANY sip-header From modify "<internal IP>" "external interface 2 IP"
 rule 20 request ANY sip-header From modify "From:(.*)(<sip:.*@.*>)" "From: \2"
 rule 70 request INVITE sip-header Diversion modify "Diversion:(.*)(<sip:)(.*)(@.*>)" "Diversion: \2+<main circuit number>\4"
 rule 80 request INVITE sip-header Diversion add "Diversion: <sip:+<main circuit number>@external interface 2 IP>"
voice class sip-profiles 21
 rule 70 request INVITE sip-header Diversion remove
voice class e164-pattern-map 1
 description E164 Pattern Map for called number to CUCM
  e164 +49XXXXXXXXXXXX
voice class e164-pattern-map 2000
 description E164 Pattern Map for called number to PSTN
  e164 +.T
voice class e164-pattern-map 2001
 description E164 Pattern Map for emergency number
  e164 0112
voice class server-group 1
 ipv4 10.xx.xx.y1 preference 1
 ipv4 10.xx.xx.y2 preference 2
 description Inbound calls from PSTN to CUCM
 huntstop 1 resp-code 404 to 404
voice class server-group 2000
 ipv4 10.XX.XX.XX preference 1
 ipv4 10.XX.XX.XX preference 2
 description BT SOTI  - IP Addresses
voice class server-group 2100
 description ** BT One Voice - IP Addresses **
voice class sip-options-keepalive 1
 description Used for Server Group SIP OPTIONS PING
voice class sip-options-keepalive 2000
 description ** BT SOTI - Options-Ping **
 down-interval 15
 retry 3
 transport tcp tls
 sip-profiles 200
voice class sip-options-keepalive 2100
 description ** BT One Voice - Options-Ping **
 down-interval 15
 retry 3
 transport udp
voice class tenant 2000
 connection-reuse
 audio forced
 session transport tcp tls
 bind control source-interface GigabitEthernet0/0/1
 bind media source-interface GigabitEthernet0/0/1
voice class tenant 2100
 audio forced
 bind control source-interface GigabitEthernet0/0/2
 bind media source-interface GigabitEthernet0/0/2
voice class tenant 1
 bind control source-interface GigabitEthernet0/0/0
 bind media source-interface GigabitEthernet0/0/0
dial-peer cor custom
 name CM
 name PSTN-SOTI
 name PSTN-GSIP
dial-peer cor list CM-IN
 member PSTN-SOTI
 member PSTN-GSIP
dial-peer cor list CM-OUT
 member CM
dial-peer cor list PSTN-SOTI-OUT
 member PSTN-SOTI
dial-peer cor list PSTN-SOTI-IN
 member CM
dial-peer cor list PSTN-GSIP-OUT
 member PSTN-GSIP
dial-peer cor list PSTN-GSIP-IN
 member CM
dial-peer voice 1000 voip
 corlist incoming CM-IN
 description Outbound calls from CUCM
 session protocol sipv2
 incoming uri via CUCM
 voice-class codec 1
 voice-class sip tenant 1
 dtmf-relay rtp-nte sip-kpml
 no vad
dial-peer voice 1010 voip
 corlist outgoing CM-OUT
 description Inbound calls to CUCM
 session server-group 1
 destination e164-pattern-map 1
 voice-class codec 1
 voice-class sip options-keepalive profile 1
 no vad
dial-peer voice 100 voip
 corlist incoming PSTN-SOTI-IN
 translation-profile incoming PSTN-IN
 max-conn 150
 incoming uri via PSTNSOTI
 voice-class codec 10
 voice-class sip profiles 100 inbound
 voice-class sip tenant 2000
 dtmf-relay rtp-nte
 srtp
 no vad
dial-peer voice 110 voip
 corlist outgoing PSTN-SOTI-OUT
 description Outbound calls to PSTN
 translation-profile outgoing PSTN-OUT
 huntstop
 max-conn 150
 session server-group 2000
 destination e164-pattern-map 2000
 voice-class sip options-keepalive profile 2000
 dtmf-relay rtp-nte
 srtp
 no vad
dial-peer voice 120 voip
 description Emergency calls to PSTN
 huntstop
 max-conn 150
 destination e164-pattern-map 2001
 voice-class sip profiles 20
 dtmf-relay rtp-nte
 srtp
 no vad
dial-peer voice 200 voip
 corlist incoming PSTN-GSIP-IN
 description Inbound calls from PSTN-GSIP
 redirect ip2ip
 incoming uri via PSTNGSIP
 voice-class sip early-offer forced
 voice-class sip tenant 2100
 dtmf-relay rtp-nte
 fax-relay sg3-to-g3
 fax rate 9600
 fax nsf 000000
 fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 1 fallback pass-through g711ulaw
 no vad
dial-peer voice 210 voip
 corlist outgoing PSTN-GSIP-OUT
 description Outbound calls to PSTN-GSIP
 huntstop
 session server-group 2100
 voice-class sip profiles 11
 voice-class sip options-keepalive profile 2100
 dtmf-relay sip-kpml rtp-nte sip-notify
 fax-relay sg3-to-g3
 fax rate 9600
 fax nsf 000000
 no vad
dial-peer voice 220 voip
 description Emergency calls to PSTN-GSIP
 huntstop
 voice-class sip profiles 21
 no vad
sip-ua
 no remote-party-id
 retry invite 2
 timers trying 300
 timers connection establish tls 5
 transport tcp tls v1.2 minimum
  crypto signaling default trustpoint <name of choice> cn-san-validate server
 g729-annexb override
no dial-peer voice 100 voip !Can possibly be removed as it's a H.323 dial peer
no dial-peer voice 101 voip !Can possibly be removed as it's a H.323 dial peer
dspfarm profile 10 transcode universal
 codec g729abr8 !Remove as B = VAD and you're not using that
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729br8 !Remove as B = VAD and you're not using that
 codec g729r8
 codec g722-64
 maximum sessions 12
 associate application SCCP
*** Bonus ** It would be advisable to use VRFs to split the two SIP trunks, but not technically an absolute must
ip vrf BTSOTI
 rd 1:1
ip vrf BTGSIP
 rd 2:2
 description WAN interface to BT SOTI
 ip vrf forwarding BTSOTI
  ip access-group BTSOTI_ACL in !You should use an ACL to filter what traffic is allowed to/from ITSP
 description WAN interface to BT One Voice
 ip vrf forwarding BTGSIP
 ip access-group BTGSIP_ACL in !You should use an ACL to filter what traffic is allowed to/from ITSP
ip route vrf BTGSIP 0.0.0.0 0.0.0.0 10.1X.XX.XX name EXT_TO_BTGSIP_DEFAULT
ip route vrf BTSOTI 0.0.0.0 0.0.0.0 10.2X.XX.XX name EXT_TO_BTSOTI_DEFAULT
Response Signature
