Secure desk mount for Cisco IP Phone
k.latham
I need to securely mount several phones (~20) to desks for a customer.  The Cisco locking phone brackets are all seem designed for wall mount only.  Has anyone found a bracket that works with a desk? Or have they modified the Cisco brackets to work horizontally?
I have suggested a short Kensington cable with one of the phones that has the slot, but they are still concerned about them being used as a weapon.
-Kevin
Manish Gogna
Hi Kevin,
Please check this
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7962g_7961g_7961g-ge_7942g_7941g_7941g-ge/9_0/english/admin_guide/P746_BK_IC15BCED_00_adminguide-7941g-7941g-ge-7942-7961g-7961g-ge-7962g/P746_BK_IC15BCED_00_adminguide-7941g-7941g-ge-7942-7961g-7961g-ge-7962g_chapter_011.html#P746_TP_P5F7AA02_00
Manish
Jaime Valencia
What kind of environment is this that they would use the phone as a weapon?
I know some companies like CyberData have some cases for phones for places like jails.
java
if this helps, please rate
It's a mental health facility and has an area similar to a prison, where these phones will be installed.
OK, then I do suggest you give them a call and maybe they have something you could use for such environment.
http://www.cyberdata.net/
java
