Secure RTP em Gateways SIP
Pessoal,
Preciso habilitar criptografia (Somente SRTP) em Gateways utilizando o IOS c3900-universalk9-mz.SPA.151-4.M2.bin, com uck9.
Habilitei somente o comando a seguir. (Observação: Não identifiquei nenhum outro comando para Secure RTP.)
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
session transport tcp
srtp negotiate cisco
Utilizo sinalização SIP em todos os Gateways. E tenho as dúvidas a seguir:
- Estou configurando corretamente?
- Qual o comando mais apropriado para verificar o SRTP?
- Verifiquei a saída do comando show call active voice e o parâmetro SRTP está igual a off.
Desde já agradeço.
Luciane de Medeiros
paolo bevilacqua
Unless you post in English, your chances of getting a good answer, are very diminished.
Hi Paolo,
I need to enable encryption (SRTP Only) in Gateways using IOS c3900-universalk9-mz.SPA.151-4.M2.bin with uck9.
I enabled only the following command. (Note: I have not identified any other commands for Secure RTP.)
voice service voip
  sip
   Average bind source-interface Loopback0
The SIP protocol is used on all Gateways. And I have the following questions:
- I configured correctly?
- What is the most appropriate command to check the SRTP?
- I checked the output of the show call active voice command and the parameter SRTP is equal off.
Thank you.
