setting up 3 new PRIs on 2951
cooperma31
We are setting up 3 new PRIs on a 2951 with Frontier.  We received 300 DIDs as part of the setup.  The PRIs are registered with CUCM, and they show up on the router.  However, when we try to make an incoming call with one of the new DIDs, the calling phone is silent for about 7 seconds, rings destination for like half a second and immediately disappears.  We receive the message all circuits are busy on the calling phone.  Looking at the debug, this is what I see for the call.  Any thoughts?
Jun  1 18:41:44.673: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x1A2D
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9F8B0100A10F02017706072A8648CE1500040A0100
                Protocol Profile =  Networking Extensions
                0xA10F02017706072A8648CE1500040A0100
                Component = Invoke component
                        Invoke Id = 119
                        Operation = InformationFollowing (calling_name)
                                Name information in subsequent FACILITY message
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x2183, '7659938656'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '7659839199'
Jun  1 18:41:44.677: ISDN Se0/1/0:23 Q931d: srl_send_l3_pak:
        source_id = CCM MANAGER 0x0003, dest_id = Q.921 0x0000, prim = DL_DATA_REQ 0x0240
        priv_len = 4 int_id = 0x155C633C datasize = 26
Jun  1 18:41:44.677: ISDN Se0/1/0:23 Q931d: data =
Jun  1 18:41:44.677:    155C633C00000003024004BC00010000
Jun  1 18:41:44.677:    08029A2D0D1803A98381
Jun  1 18:41:44.677: ISDN Se0/1/0:23 Q931: TX -> SETUP_ACK pd = 8  callref = 0x9A2D
itc-row1rack1-MG01#
Jun  1 18:41:44.677: ISDN Se0/1/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x1A2D
        Facility i = 0x9F8B0100A117020178020100800F574952454C4553532043414C4C4552
                0xA117020178020100800F574952454C4553532043414C4C4552
                        Invoke Id = 120
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = WIRELESS CALLER
Jun  1 18:41:44.713: ISDN Se0/1/0:23 Q931: RX <- STATUS pd = 8  callref = 0x1A2D
        Cause i = 0x82E10D - Message type not implemented
        Call State i = 0x06
itc-row1rack1-MG01#
Jun  1 18:41:48.673: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x1A2D
                Standard = CCITT
                        Invoke Id = 119
itc-row1rack1-MG01#
itc-row1rack1-MG01#
Jun  1 18:41:50.697: ISDN Se0/1/0:23 Q931d: srl_send_l3_pak:
        priv_len = 4 int_id = 0x155C633C datasize = 21
Jun  1 18:41:50.697: ISDN Se0/1/0:23 Q931d: data =
Jun  1 18:41:50.697:    155C633C00000003024004BC00010000
Jun  1 18:41:50.697:    08029A2D02
Jun  1 18:41:50.701: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x9A2D
Jun  1 18:41:50.701: ISDN Se0/1/0:23 Q931d: srl_send_l3_pak:
        priv_len = 4 int_id = 0x155C633C datasize = 25
Jun  1 18:41:50.701: ISDN Se0/1/0:23 Q931d: data =
Jun  1 18:41:50.701:    155C633C00000003024004BC00010000
Jun  1 18:41:50.701:    08029A2D011E028088
Jun  1 18:41:50.701: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x9A2D
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Jun  1 18:41:50.761: ISDN Se0/1/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x1A2D
        Cause i = 0x82E018 - Mandatory information element missing
Jun  1 18:41:50.785: ISDN Se0/1/0:23 Q931d: srl_send_l3_pak:
Jun  1 18:41:50.785: ISDN Se0/1/0:23 Q931d: data =
itc-row1rack1-MG01#
Jun  1 18:41:50.785:    155C633C00000003024004BC00010000
Jun  1 18:41:50.785:    08029A2D4D
Jun  1 18:41:50.785: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x9A2D
Jun  1 18:41:50.861: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x1A2D
11 Replies 11
Deepak Mehta
HI Cooper,
I would make sure the the switch type and PCM type(ulaw for T1) is set correctly on GW config on CUCM.You might to involve service provider to make sue D channel is error free at their end.thanks
As per logs soon after transmitting the alerting message you receive a disconnect.
I will check this.  I can say the Telco is saying it isn't their issue.  In their words, when we call 765-983-9199 the call rings the endpoint and they see it coming in on channel 1 and immediately jump to channel 2 to see if it is accepted there.  Funny thing, one number we have 765-965-5555 comes in on one of the PRIs and works just fine.
Edit -  we are using PRI NI2 and PCM Type of u-Law
A few things:
- Can you do "sh isdn status" and make sure it says "Multiple frame established"?
- How many digits do you use in your extension? The carrier is sending 10 digits in, you will need to reduce the digits via the gateway page or translation pattern in CUCM.
- Can you post a sh run and gateway page in CUCM?
FG
I do see multiple frame established on all three PRIs.  we reduce it down to 4 or 5 digits via translation.
here is the config
boot system flash:/c2951-universalk9-mz.SPA.154-3.M3.bin
boot-end-marker
card type t1 0 0
card type t1 0 1
clock timezone EST -5 0
clock summer-time EDT recurring
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
network-clock-select 3 T1 0/1/0
isdn switch-type primary-4ess
trunk group 15B-PRI
 description itc-row1rack1-MG01 PRI's
 hunt-scheme least-used both
 translation-profile incoming SRST-DID-STRIP
cts logging verbose
voice-card 0
 dspfarm
 dsp services dspfarm
 no local-bypass
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
 fax protocol pass-through g711ulaw
 modem passthrough nse codec g711ulaw
 h323
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729br8
 codec preference 4 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 1
 rule 1 /9833184/ /8474/
 rule 2 /9833186/ /8474/
 rule 3 /^.*\(....\)/ /\1/
voice translation-profile SRST-DID-STRIP
 translate called 1
controller T1 0/0/0
 cablelength long 0db
 pri-group timeslots 1-24 service mgcp
 description Frontier PRI 31/ipzx/612163.FTNC
controller T1 0/0/1
 description Frontier PRI 31/ipzx/612161.FTNC
controller T1 0/1/0
 description Frontier PRI 31/ipzx/612162.FTNC
controller T1 0/1/1
class-map match-any Media
 match ip dscp ef
class-map match-any Control
 match ip dscp af31
 match ip dscp cs3
policy-map Voice
 class Media
  set ip dscp ef
 class Control
  set ip dscp cs3
interface Serial0/0/0:23
 no ip address
 encapsulation hdlc
 isdn switch-type primary-ni
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 no cdp enable
interface Serial0/0/1:23
 no ip address
 encapsulation hdlc
 no cdp enable
interface Serial0/1/0:23
 no ip address
 encapsulation hdlc
 no cdp enable
interface Serial0/1/1:23
 no ip address
 encapsulation hdlc
 no cdp enable
mgcp
mgcp call-agent cm02 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm x.x.x.x.identifier 3 version 4.1
sccp ccm x.x.x.x identifier 2 version 4.1
sccp ccm x.x.x.x identifier 1 version 4.1
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register CFB-1501-MDF-MG
 registration retries 10
 registration timeout 30
 switchback method graceful
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager redundant-host cm02 cm01
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server x.x.x.x.
ccm-manager config
dspfarm profile 1 conference
 codec g711ulaw
 maximum sessions 6
 associate application SCCP
 shutdown
dial-peer voice 999 voip
 description IP Catch-All
 modem passthrough nse codec g711ulaw redundancy
 incoming called-number .
 voice-class codec 1
 voice-class h323 1
 fax rate disable
 no vad
dial-peer voice 1 pots
 trunkgroup 15B-PRI
 description SRST -- OUTBOUND POTS (INTERNATIONAL)
 destination-pattern 9011T
 progress_ind setup enable 3
 progress_ind alert enable 8
 progress_ind progress enable 8
 progress_ind connect enable 8
 fax rate disable
 prefix 011
dial-peer voice 2 pots
 trunkgroup 15B-PRI
 description SRST -- OUTBOUND POTS (411)
 destination-pattern 9411
 fax rate disable
 forward-digits 3
dial-peer voice 3 pots
 trunkgroup 15B-PRI
 description SRST -- OUTBOUND POTS DIALING LD
 destination-pattern 91[2-9]..[2-9]......
 fax rate disable
 forward-digits 11
dial-peer voice 4 pots
 trunkgroup 15B-PRI
 description SRST -- OUTBOUND POTS DIALING Local
 destination-pattern 9[2-9]......
 fax rate disable
 forward-digits 7
dial-peer voice 10 pots
 trunkgroup 15B-PRI
 description SRST -- INBOUND PRI
 fax rate disable
 direct-inward-dial
dial-peer voice 911001 pots
 trunkgroup 15B-PRI
 description SRST -- 911 DIALING POTS
 translation-profile outgoing SRST-OUTBOUND-CLID
 destination-pattern 9911
 forward-digits 3
dial-peer voice 1000 voip
 description SRST -- INBOUND VOIP
 voice-class codec 1
 voice-class h323 1
dial-peer voice 9911001 pots
 trunkgroup 15B-PRI
 forward-digits 3
Please can you also attached the MGCP config for 0/1/0 from the CUCM.
You have to make sure the Inbound CSS for gateway has access to the all DN's parition you are trying to reach and also significant digits can be set to 4 if you are using only last 4 digits as extension as service provider is sending full 10 digits.
I will try to upload the pics right now.
Here are the screenshots
Please can you make sure in Inbound calls section on GW config.
1) You have the Inbound CSS for gateway which has access to the all DN's partitions you are trying to reach
2) Significant digits can be set to 4 if you are using only last 4 digits as extension as service provider is sending full 10 digits.
i have confirmed that both of those settings are correct.  CW- INbound has everything in it, and we are matching at 10 digits with the teleco, which contradicts what i said earlier.
Could it be a dial peer or a route pattern that is causing this issue?
It is MGCP so dial-peer doesn't matter . These are only for SRST.
Do you still see the same error  ,if yes then you might want to check with provider if you think on CUCM correct translations are applied .
oops it split them
