showing DSP in use
iptuser55
Level 6
Level 6
Excuse the weird question, I`m trying to find out how many DSP we have used. I know we can use use SH DSP , SH VOICE DSP VOICE etc but Im tryng to remember the other commend I think it is something like Show MS.... or MB.... etc It shows what are being used and what are spare
Many thanks
5 Replies 5
Payal Bhaduri
The show voice dsp group all can show you the dsp usage.
You can use "show voice dsp group all".  An example of such
output is:
W1MS-C#sh voice dsp group all
DSP groups on slot 0:
This command is not applicable to slot 0
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
DSP groups on slot 3:
dsp 1:
  State: UP, firmware: 4.4.19
  Max signal/voice channel: 6/6
  Max credits: 240
  Group: FLEX_GROUP_VOICE, complexity: HIGH
    Shared credits: 210, reserved credits: 0
    Signaling channels allocated: 4
    Voice channels allocated: 1
    Credits used: 30
    Voice channels:
      Ch01: voice port: 3/0/0.1, codec: g729r8, credits allocated: 30
  0 DSP resource allocation failure
Pl rate useful info. Thanks
abukuru95
Level 3
Level 3
hi Payal,
piece of cake.
use the show diag
rate if this helps
The show diag will not show the dsp's that are spare and the dsp's that are actually in use.It will just give you all the PVDM's that are in the router.
bhuvanesh.s49
Hi Payal,
Use "Show call resource voice stats" this will show the active DSP utilization in Voice gateway.
Please is example of output
DSP Statistics:
Utilization: 0 percent
Total channels: 120
Inuse channels: 35
Disabled channels: 0
Pending channels: 0
Free channels: 85
DS0 Statistics:
Total channels: 96
Addressable channels: 48
Inuse channels: 35
Disabled channels: 24
Free channels: 13
