Problems with option 0 in B-ACD CME 7.1
End user has CME 7.1 with B-ACD configured, options dial-by extension, option 2 and 3 are configured and works fine, but option 0 (dial 0  to be routed to operator) does not work. Eventhough the pilot and extension number are configured all the times the call is routed to extensión 112.
I don not know why... I need to know the reason of this issue. or if there is something wrong with config.
I attach the config file, I hope any of you can give any suggestion.
regards.
paolo bevilacqua
Option 0 is always routed to the highest numbered aa-hunt.
This behavoir cannot be changed.
Hi Paolo,
I associated option 0 with highest aa-hunt, but the call is not routed to extension I set (101).
the call is sent to extension 112.
service queue flash:app-b-acd-3.0.0.2.tcl
  param aa-hunt3 303
  param queue-len 5
  param aa-hunt4 304
  param queue-manager-debugs 1
  param number-of-hunt-grps 3
  param aa-hunt2 302
ephone-hunt 4 longest-idle
pilot 304
list 101
you should define two DN for the list in the ephone-hunt
Try doing like this:
list 101 *101
let *101 as a secondry DN for 101 in the ephone-dn , so it'll always ring the needed phone
Hi Filiberto
Refer this script for routing the call to the Operator. DTMF option "0" routes the call to the operator.
By default, the  highest aa-huntX group is defined as the operator  one
ACD Script - Call Routing/Queue
Responsible for routing the call to a huntgroup and queue the call when  members of the huntgroup are all busy.
Call-Queue and AA Tcl Scripts in Flash Memory
Router(config)#application
Router(config-app)#service queue flash:app-b-acd-3.0.0.2.tcl
Router(config-app-param)#param number-of-hunt-grps 3
! -- MUST BE SET. Tells the system how many entries are present in the  menu
Router(config-app-param)#param aa-hunt1 6100
! -- Menu option 1 goes to 6100
Router(config-app-param)#param aa-hunt2 6101
! -- Menu option 2 goes to 6101
!-- DTMF option "0" routes the call to the operator. By default, the  highest aa-huntX group is defined as the operator one
Router(config-app-param)#param aa-hunt10 1000
! -- Here I put aa-hunt10 to 1000 where 1000 is the extension of the  operator
Router(config-app-param)#param queue-len 15
Router(config-app-param)#param queue-manager-debugs 1
******* show *************
param aa-hunt1 6100
param aa-hunt2  6101
param queue-len 15
Pl rate if info is helpful. Thanks.
