sip/2.0 403 forbidden
Sheikh
Hi, hope you are having good time. I have a VPN between our PK and US office, and I am are facing "sip/2.0 403 forbidden" error when I try to call from US to PK extension numbers. US to US and PK to US dialing is perfectly fine, only US to PK dialing is showing this error. I am attaching show ccsip message and show ccsip calls.
can anyone please adivse?
17 Replies 17
Greg, both tricks didn't work, I'll provide logs today.
Dear Greg,
Thanks for your support. The issue has been resolved, actually you were
right at first point, toll fraudulent prevention mechanism was restricting
calls from US router to PK router. After adding
Voice service VoIP and
ip address trusted list
Ipv4 xxxx xxxx
Ipv4 xxxx xxxx
Calls are connecting successfully....
Great please mark post as solved so others with problem can find answer quickly.
