SIP/2.0 580 Precondition Failed - CME Outbound call
markmarvinq
We are having issue with outbound call having Preconditioned Failed error. Inbound call is working fine.
Checked with our ISP but they are saying internal configuration. Please assist. Below configuration and attached logs
voice register pool  1
 busy-trigger-per-button 2
 id mac 1111.2222.3333
 type 8841
 number 1 dn 1
 dtmf-relay sip-notify
 voice-class codec 1
voice register pool  2
 id mac 4444.5555.6666
 type 8841
 number 1 dn 2
 voice-class codec 1
voice translation-rule 20
 rule 1 /^69../ /5506\0/
voice translation-profile ANI
 translate calling 20
dial-peer voice 98 voip
 description #### FT Trunk 1: x.x.x.x ####
 translation-profile outgoing ANI
 destination-pattern .T
 modem passthrough nse codec g711ulaw
 session protocol sipv2
 session target ipv4:x.x.x.x:5060
 voice-class codec 1
 dtmf-relay h245-alphanumeric cisco-rtp h245-signal rtp-nte sip-kpml sip-notify
 fax rate disable
 no vad
dial-peer voice 99 voip
 description #### FT Trunk 2: y.y.y.y ####
 huntstop
 session target ipv4:10.y.y.y.y:5060
 voice-class codec 1
 fax rate disable
 no vad
Jonathan Schulenberg
The provider needs to tell you what their SBC doesn’t like about your INVITE. The response itself just says “classification failure.” That doesn’t tell us what they expect changed.
Not directly related to your issue, but these two dtmf relay options are for H.323, h245-alphanumeric and h245-signal, and as you use SIP these are not applicable. Recommend you to remove them.
Response Signature
As others mentioned, your ISP must tell you what they don't like with your Invite.
Response Signature
