01-31-2018 06:31 AM - edited 03-17-2019 12:05 PM
I have been setting up CUBE to register with a service provider. The provider expects:
Digest username="+25675440000@provider.com",.........
but CUBE is sending this:
Authorization: Digest username="+25675440000",realm="provider.com",uri="sip:provider:5060",response="17c1db1cf80b0c4c0252ada3745d4130",nonce="UQn9BVDZqPnER5PeQl8IfQ==",cnonce="FFFFFFFF",qop=auth,algorithm=MD5,nc=00000001
However when I modify the sip profile as below; It affects all values that have "" (quatations)
request REGISTER sip-header Authorization modify "Digest username=\"+25675440000\"" "Digest username=\"+25675440000@provider.com\""
the result is:
Authorization: Digest username="+25675440000@provider.com",qop=auth,algorithm=MD5,nc=00000001
When i run it as just below; it remains unchanged;
request REGISTER sip-header Authorization modify "+25675440000" "+25675440000@provider.com"
Kindly advise how I can modify just the Digest username field. Am really new to this. Thank you.
01-31-2018 08:31 AM
02-01-2018 12:00 AM
Hi Nipun,
The username provided is +25675440000
But he needs +25675440000@provider.com in the Authorization header
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 10.156.0.249:5060;branch=z9hG4bK11917B4
Call-ID: 2A459290-5E611E8-FFFFFFFF80028391-FFFFFFFF92276292
From: <sip:+25675440000@provider.com>;tag=2EB117E-11C8
To: <sip:+25675440000@provider.com>;tag=hywclbec
CSeq: 283 REGISTER
WWW-Authenticate: Digest realm="provider.com",nonce="XpFRIk4p1EWhylCF2tS5zg==",algorithm=MD5,qop="auth"
Content-Length: 0
02-01-2018 08:48 AM
02-01-2018 10:51 AM
I have tried this but it affects the To, From and contact headers of the REGISTER message sent to the provider
The display becomes <sip:+25675440000@provider.com@provider.com>
This is not recognized by the provider
02-01-2018 11:21 AM
01-03-2020 05:17 AM
Hello @sameul.mumbere @R0g22
I have the same problem.
Could you solve the problem? did you modify the Digest username field?
01-06-2020 07:08 AM
Can you post up your current sip-ua configuration, and your outbound Register and other messages where you need to modify the username? I expect a SIP profile could do the trick but there may be better ways.
Really what we want to see is what you're actually sending, and a description of what your ITSP says you should be sending.
01-06-2020 09:11 AM
Hello @TONY SMITH
Thanks for your reply, but I got the solution to my case:
I was useing this config normaly:
sip-ua
credentials username 123@test.com password 123456 realm test.com
and I changed with this:
credentials number 123456 username 123456@test.com password 123456 realm test.com
