SIP Call Block Fails
writchey
I have configured call blocking inbound on a SIP trunk but the call blocking is not working.  Configuration is below.  I have moved the block commands to every dial peer and back again and still call block fails.  Using VzB sip trunks with 2801running ios 12.4.20 T4.
voice translation-profile block_harassing_calls
translate calling 4
voice translation-rule 4
rule 1 reject /254702010495/
dial-peer voice 101 voip
description voip dial peer from Verizon for Voice
translation-profile incoming block
call-block disconnect-cause incoming user-busy
Thank you for your help.
Under the dial-peer, use this config instead:
call-block translation-profile incoming block
Using a standard incoming translation profile configuration will not work for call blocking.
writchey
Update:  At first glance it looks like my profile names do not match but here is the correction.
translate calling 4
Success.  Thanks much for the quick reply.
