SIP Call rings continues but destination phone is switched off
@Syed
Level 3
Level 3
Dear All,
I have a problem with SIP trunk.
Problem Description >
I am dialing an external phone number (mobile number in this case) from my IP phone registered to CUCM 11.5 and I know the mobile is switched off, but I get ringing tone still.
Could someone give me a clue as to what is causing this behavior.
Call Flow>
IP phone > CUCM 11.5 > SIP Trunk > CUBE > ITSP
Dennis Mink
Send debug ccsip message please. The ringi g follows after the trying is received and the responder can actuall ring the destionation. Without debugs it is not possible to determine wherr the false positive ringing occurs. Or if this is expected behaviour
Please remember to rate useful posts, by clicking on the stars below.
Dennis,
I have attached the call logs. I see no 180 ringing in the logs.
Calling number > 3061090
Called number > 90565549955
Thank you
