SIP Debug Errors Question
bradleyordner
Level 3
Level 3
The other day we lost voice calls via our SIP Trunks. I have spoken with 3rd Party, although no Root Cause from them. I have some debugs, which seem to point to otherwise and wanted to know if I am reading them correctly.
We believe a DNS issue was stopping us from contacting the SIP Registration Server although we could resolve the name to IP on the CMD line during the outage.
The following below is a debug and show command during outage -
SIP UAS CALL INFO
Call 1
SIP Call ID                : ed817c80-fea18ae6-f7a59-36af80a@x.x.x.x
   State of the call       : STATE_RECD_INVITE (11)
   Substate of the call    : SUBSTATE_NONE (0)
   Calling Number          :xxxxxxxxx
   Called Number           : xxxxxxxxx
   Bit Flags               : 0x40201C 0x10000100 0x80000
   CC Call ID              : 684
--More-- _________        _________   Source IP Address (Sig ): x.x.x.x
   Destn SIP Req Addr:Port : [x.x.x.x]:5060
   Destn SIP Resp Addr:Port: [x.x.x.x]:5060
   Destination Name        : x.x.x.x
   Number of Media Streams : 1
   Number of Active Streams: 0
   RTP Fork Object         : 0x0
   Media Mode              : flow-through
   Media Stream 1
     State of the stream      : STREAM_IDLE
     Stream Call ID           : -1
     Stream Type              : voice+dtmf (1)
     Stream Media Addr Type   : 1
     Negotiated Codec         : No Codec    (0 bytes)
     Codec Payload Type       : 255 (None)
     Negotiated Dtmf-relay    : inband-voice
     Dtmf-relay Payload Type  : 0
     QoS ID                   : -1
     Local QoS Strength       : BestEffort
     Negotiated QoS Strength  : BestEffort
     Negotiated QoS Direction : None
     Local QoS Status         : None
     Media Source IP Addr:Port: [x.x.x.x]:28240
Options-Ping    ENABLED:NO    ACTIVE:NO
   Number of SIP User Agent Server(UAS) calls: 1
#sho sip-ua calls | inc Codec
#debug ccsip error
SIP Call error tracing is enabled
Jun 27 15:00:30 AEST: //1014903/00E31680000F/SIP/Error/act_sentinvite_wait_100: Out of retries
Jun 27 15:00:30 AEST: //-1/xxxxxxxxxxxx/SIP/Error/_send_dns_fail: DNS Query for x.x.x.com failed
Jun 27 15:00:30 AEST: //1014903/00E31680000F/SIP/Error/act_idle_dns_resolved: DNS Query failed for query_type:1
Jun 27 15:00:30 AEST: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
Jun 27 15:00:30 AEST: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
Jun 27 15:00:30 AEST: //1014903/00E31680000F/SIP/Error/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Invalid CCB/Data/Container
au-corp-bne-vr02#
au-corp-bne-vr02#
Jun 27 15:00:31 AEST: //1014913/03DE0700000F/SIP/Error/sipSPI_ipip_set_history_info_header: ccb->src_addr_str is NULL
SIP: (1014913) Group (a= group line) attribute, level 65535 instance 1 not found.
Now I believe the SIP protocol was pointing to a 3rd Party Server for DNS in this command -
sip-ua
  registrar dns:x.x.x.com expires 3600
sip-server dns:x.x.x.com
connection-reuse
g729-annexb override
We also were not registered when doing the show sip-ua register status command.
I honestly believe nothing was wrong on our end, just wondering if I am on the right track......
Thanks!
paolo bevilacqua
Take debug ccsip message to see what happens.
I can't do that debug now as problem is not happening anymore.
