sip Disconnect Cause (CC): 16 Disconnect Cause (SIP): 487 call keep ringing
CLAUDIO RIVAS
Currently i have an scenario with
alcatel (h323) -> 2921 -> SIP Trunk -> Carrier Softswitch
When i call to a PSTN number form an alcatel extension by going through the SIP Trunk from the alcatel extension i herd ringback, and on the PSTN phone rings, when the phone is answered then there is a silence on the call and then sudently drop the call.
I collected the sip debg info
2012-09-14 10:08:43          Local7.Notice          172.16.4.2          5825010: *Sep 14 09:49:34: %SYS-5-CONFIG_I: Configured from console by sistlajo on vty0 (172.16.1.43)
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825011: *Sep 14 10:06:59: //2141100/00809F331317/SIP/Call/sipSPICallInfo:
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825012: The Call Setup Information is:
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825013: Call Control Block (CCB) : 0x9AA6D58
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825014: State of The Call        : STATE_DEAD
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825015: TCP Sockets Used         : NO
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825016: Calling Number           : 3324004900
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825017: Called Number            : 37700028
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825018: Source IP Address (Sig  ): 10.15.0.22
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825019: Destn SIP Req Addr:Port  : 10.255.252.134:5060
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825020: Destn SIP Resp Addr:Port : 10.255.252.134:5060
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825021: Destination Name         : 10.255.252.134
2012-09-14 10:26:08          Local7.Debug          172.16.4.2          5825022:
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825023: *Sep 14 10:06:59: //2141100/00809F331317/SIP/Call/sipSPIMediaCallInfo:
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825024: Number of Media Streams: 1
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825025: Media Stream             : 1
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825026: Negotiated Codec         : g711alaw
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825027: Negotiated Codec Bytes   : 160
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825028: Nego. Codec payload      : 8 (tx), 8 (rx)
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825029: Negotiated Dtmf-relay    : 6
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825030: Dtmf-relay Payload       : 101 (tx), 101 (rx)
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825031: Source IP Address (Media): 10.15.0.22
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825032: Source IP Port    (Media): 0
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825033: Destn  IP Address (Media): 172.16.250.29
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825034: Destn  IP Port    (Media): 31100
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825035: Orig Destn IP Address:Port (Media): [ - ]:0
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825036:
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825037: *Sep 14 10:06:59: //2141100/00809F331317/SIP/Call/sipSPICallInfo:
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825038: Disconnect Cause (CC)    : 16
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825039: Disconnect Cause (SIP)   : 481
2012-09-14 10:26:09          Local7.Debug          172.16.4.2          5825040:
Here is the meaningful part of my configuration:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol pass-through g711ulaw
h323
  call preserve
modem passthrough nse codec g711ulaw
--More--          sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
voice class codec 10
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class codec 11
codec preference 1 g729r8
codec preference 3 g711ulaw
voice class codec 12
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class h323 1
--More--           h225 timeout tcp establish 3
voice translation-rule 10
rule 1 /\([^9].*\)/ /9\1/
voice translation-rule 20
rule 1 /^9/ //
voice translation-rule 21
rule 1 /..../ /3324004900/
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.16.4.2 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.4.2
ip address 10.15.0.22 255.255.255.0
duplex auto
--More--          speed auto
media-type rj45
no cdp enable
ip route 0.0.0.0 0.0.0.0 172.16.4.1
ip route 10.255.252.134 255.255.255.255 10.15.0.254
ip route 172.16.250.0 255.255.255.0 10.15.0.254
ip route 172.16.253.0 255.255.255.0 10.15.0.254
dial-peer voice 4011 voip
description ~-~-~-~-~-~-~-Dir 937700028~-~-~-~-~-~-~-
translation-profile outgoing SalidaSIP2
preference 2
destination-pattern 937700028
session protocol sipv2
session target ipv4:10.255.252.134
session transport udp
voice-class codec 12
dtmf-relay rtp-nte h245-alphanumeric h245-signal cisco-rtp sip-kpml sip-notify
no vad
as you can notice i hardcoded the phone number i'm trying to reach,
Hope to find help soon, on advice thanks!
29 Replies 29
Hi Aok,
Thank you for your response, i placed the early-offer forced under the sip configuration, but stills the same result.
Sorry about the question but, On CCO you mean Cisco website?
Aok means to login into cisco.com with your cco(Cisco account) and check configuration guide for your case
Personal i believe that the issue is with the ISP , but its better to check it again that your config is correct , between alcatel and CUBE
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
For me seems an issue with Alcatel and CUBE, because currently i'm ussing the same trunk and even same gateway and dial-peers for dial out from a CallManager on the same network without problems, but at this point i'm short of ideas.
Best regards,
Claudio
Do you have cco in cisco?
If no tell me your alcatel model and i will try to find the confguration guide
Also ISP must be able to give you some ideas about the issue i think and structure you what you have to change regarding their traces
One question:
Did you create a dial peer for calls coming to cube from alcatel?
dial-peer voice 100 voip
incoming called-number .
voice-class h323 1
dtmf-relay h245-alphanumeric
fax rate disable
no vad
Hi Chrys,
Yes i got one, but cant find a document for Alcatel OmniPCX Office, just for the 4400 .
Regarding the dial-peer I have this configuration
dial-peer voice 2 voip
voice-class codec 11
and about the voice class codec i have this configuration:
voice class h323 1
So i think this could be a codec missconfiguration, as this kind of calls uses first the g729r8 but the call from alcatel to voice gateway is suposed to be stablished by g711alaw and the calls from the voice gateway to the sip trunk uses the same codec (g711alaw).
My next try will be to use your configuration once i get on site tomorrow.
I would like to know whats your deep thinking about this, for me seems interesting and logicaly correct what you are suggesting but i need to understand a little bit more about this.
Claudio.
Hi Chrys,
I've tryied with the configuration for the dial-peer as you suggested:
voice-class h323 1
fax rate disable
no vad
The main result is the same, the caller listen ringing until fast busy, and the pstn phone listen nothing but silence until the call drops. The difference is that the caller and callee have the fast busy faster than the other times, i suppose that this is because the order of the codec is first on the g711alaw for the voice class 12.
I attached some logs, which are the same for Aok.
Claudio.
Claudio,
Please send your CUBE traces after enabling early offer..Let me know the called and calling number
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Hi Aok,
Here is the log file, i think it's not complete, tomorrow i will place same test again. Do you think i need any particular debugs?
Is this the called number 37980899 ?
Can you explain the set up better...Is this diagram correct?
Alcatel---h323--->CUBE--sip trunk-->-ITSP
Where are you making the call from..Is it from alcatel to Carried? or carrier to alcatel?
Hi Aok,
Sorry about the correct answer, was an error, the call flow is correct, the called number was 37700028.
Regarding the call, yes is starting on alcatel (extensions 38XX) and going through the SIP trunk to the carrier.
Ok. The called number is not in the trace you sent..
Can you send your full config of the cube..
can you also do another test call and send
debug voip ccapi inout
debug ccsip messages
Hi Claudio,
Who is your ITSP?, for TELUM without Auth, here is my outbound config
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  g729 annexb-all
voice class codec 1
codec preference 1 g729br8 bytes 30
codec preference 2 g729r8 bytes 30
voice translation-rule 3
rule 1 /^.*/ /8122223333/
voice translation-rule 110
rule 1 /^9/ //
voice translation-profile TELUM
translate calling 3
translate called 110
dial-peer voice 2002 voip
description [][][] Llamadas Nacionales to TELUM [][][]
translation-profile outgoing TELUM
destination-pattern 901..........
session target ipv4:<>:5060
incoming called-number .T
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay rtp-nte
best regards!
HI Aok,
Thanks for your quick answer, i'll get debugs tomorrow morning. pls find on the doc the information requested.
Hi Aok,
I attached on this post the debugs you requested, the call is from 37700028 so you can find it.
Claudio.
Claudio,
In the trace I can see that the gateway used dial-peer 4011. However i do not see the configuration for that dial-peer. I also do not see the early offer forced config I suggested earlier. Is this config you sent an old config. Can you send the correct config.
ct  4 11:54:45: //2601943/00809F33070D/CCAPI/ccSaveDialpeerTag:
2012-10-04 12:16:31,local7.debug,172.16.4.2, 27821960:    Outgoing Dial-peer=4011
