05-24-2018 08:06 AM - edited 03-17-2019 12:52 PM
We have a voice PRI connected to an ISR 4451. The ISR is configured in CallManager using encryption/tls as a SIP Trunk (5061). We also have an IVR configured using SIP, but without encryption (5060).
When calling the IVR directly, the call proceeds. When calling a did on the PRI that translates to the IVR, it fails. I've tried fronting with a MTP to no avail. The call is completely G711. Any suggestions for troubleshooting?
05-24-2018 08:10 AM
I forgot to mention - when I turn off encryption on the ISR 4451, the call works. So the issue has something to do with the scenario -
PSTN -- 4451 (SIP TLS/5061) -- CallManager -- IVR (SIP/5060)
05-24-2018 01:49 PM
Are you doing SRTP as well or just TLS?
If so, you'll need to configure srtp fallback since the IVR is not secure:
