Hi I need to confirm if these 2 features are now available with CUCM 12.x or still not available1- Call back for external calls2- Limit the call duration for external calls only. not the global setting for all calls Thanks
When someone calls into the office, they get disconnected. Ive done a debug ISDN q931 and here are the results:ep 11 15:38:59.511: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01 Sending Complete Bearer Capability i = 0x8090A3 ...
Hi All,Hope that all of you are safe during the pandemic.Today I'm facing an issue with a user in CUC,when user is attempting to login to voice mail box over phone, after entering PIN the call disconnects immediately by playing NO CONNECTION.Can any ...
I have recently found this tool and plan to use it to generate reports on the success of UI Automation. I am however unable to connect. There seems to be an issue with my login but I have rights in the front end. Do I need different permissions to...
Hello, Is there a way to get last registered date for devices in Call Manager 11.5.1.18900-97. I want to complete some housekeeping before moving to flex plan but not able to determine which devices are not in use any longer. Thank you.
HI, We have a scenario where user ask to display the original calling number on his mobile which is configured as SNR destination. I see in cisco community portal that, SNR is different from CallForwd and redirection number won't beIP Telephony and P...
Hi everyone, I recently have started updating our 8800 series phones (specifically 8851s) to 12.8(1) from 12.1(1) and it seems that this breaks the last line remembered. I think I need guidance, because from what I have been able to find this is the...
Dear AllI have problem with configuring sip trunk on cube, my scenario is like below:ITSP(SBC)>---------<(PBX) CUBE (sip trunk)>----------<ISSABEL>-----------IP SIP Phone └-PRI[E1]>------------< Panaso...
Dear All.My PBX is acting weird. I have configured "Presence" on it, but although "Presence" works if I checking from the router console or using the contacts list in the phone menu, on the pinned phone numbers to the buttons on the phone the phone l...
I have a 8841 that is stuck on detecting network. IPv4 settings have been manually configured and I can ping the IP phone but the phone does not move past the detecting network message. I already tried factory reset with the same results. Recreate...
I need to secure voice gateway, but i can't use some commands to enable it as >>voice service voipsipsession transport tcp tls also >>sip-uacrypto signaling remote-addr x.x.x.x 255.255.255.255 trustpoint VGW both commands don't exist at all when I ...
Hello,my provider has changed their service and no longer support the DNS configuration setting "A-Record".So my CISCO IP Phone doesn't work anymore. On the display the message is: "Checking DNS".Do you know what I have to change to bring it back to ...
Hi, I have 3 Phones 8865 on one shard line, the phones do not receive external calls simultaneously (when the external caller dial the land line then dial the shared extension) , one of them ringing only (Randomly). Can you help in this ?
Hi, May I know in our internal extension calling, can we separate it by translation pattern but using same partition and CSS? Example: internal extension call 1XXX and 2XXX with the XXX could be the same number? Can this work if the partition between...
Subject | Author | Posted |
05-16-2025 12:03 AM | ||
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM |
User | Count |
5 | |
4 | |
2 | |
1 | |
1 |
