01-26-2015 03:02 AM - edited 03-18-2019 11:27 AM
I have a CUCM 8.6.2. I use a SIP trunk to make calls but i have a loop that i cant know how to avoid it.
172.23.132.18 is the CUCM.
172.23.129.35 internal SBC
172.23.129.48 external SBC
172.23.254.245 Alcatel OXE.
I want to know how can tell CUCM to stop when a 480 is received.
Thank you so much!
01-26-2015 05:32 AM
Looks like it's coming from 172.23.254.245 Alcatel OXE, so I would reach out to the provider and have them look into it.
01-26-2015 05:35 AM
Alcatel is just responding 480 temporalily not available, i think it is a valid answer, why cucm keeps sending invites again and again...
01-26-2015 05:49 AM
What is the SBC, is it Cisco CUBE?
It looks to me that the SBC is not providing proper disconnect cause thus not sending Cancel or Bye to CUCM, with CUBE you can map cause codes to SIP messages, i.e.
sip-ua
set pstn-cuase 18 sip-status 503
set pstn-cuase 19 sip-status 503
If you have another vendor's SBC then you may want to research equivalent. Otherwise you may want to decrease Retry SIP parameters on CUCM.
01-26-2015 05:59 AM
It is an Oracle SBC ( acme packet ).
In SIP profile i have a retry value on 6 ( which is default).
Thank you so much!
02-18-2015 03:04 AM
Anyone?
04-25-2015 03:39 PM
Did you find why are you receiving 480 temporalily not available, from provider?
Thanks.
