Showing results forĀ
Search instead forĀ
Did you mean:Ā
SIP no ringback incoming call
Good day to everyone.
Have some trouble, missing ringback when calling from PSTN.
(PSTN)----(ITSP)-----sip----(CUBE )-----sip-----(CUCM)-----sccp------(ip phone)
ITSP - 192.168.102.10
CUBE - 192.168.102.9
CUCM - 10.10.2.7
CUBE config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h225 connect-passthru
  h245 passthru all
sip
  redirect contact order best-match
  pass-thru headers unsupp
  pass-thru content sdp
  no call service stop
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
voice class h323 1
dial-peer voice 88009 voip
preference 8
destination-pattern .T
redirect ip2ip
session protocol sipv2
session target ipv4:10.10.2.7
voice-class codec 1
max-redirects 10
When "pass-thru content sdp" removed from config - ringback appears, but there arising another issue: can't make transfer from IP-Phone to IP-Phone.
I've attached "debug ccsip messages" to this post. IOS: c2900-universalk9_npe-mz.SPA.151-2.T4.bin
Any help will be kindly appreciated, thanks.
10 Replies 10
Ayodeji Okanlawon
I looked at your logs, and I can see that when CUBE recieves 180 ringing from CUCM, it is changing to 183 without SDP and senidng it to your ITSP...The question is why is CUBE modifying this.
Received:
SIP/2.0 180 Ringing--------------------------------CUBE receives ringing from CUCM
Via: SIP/2.0/UDP 10.10.2.253:5060;branch=z9hG4bK870
To: <2130330>;tag=3052530~7b97bb5c-eeaf-4aea-bd1e-affb76d2fec0-58453757
Date: Wed, 29 Aug 2012 05:47:50 GMT
Call-ID: BF58CD61-F0D311E1-818EBE21-8855E779@10.10.2.253
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence
Call-Info: <10.10.2.7:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "test" <1194>
Remote-Party-ID: "test" <1194>;party=called;screen=yes;privacy=off
Contact: <2130330>
Content-Length: 0
Aug 29 05:46:43.697: //139/BF5831398188/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress---------------CUBE changes it to 183 session progress
Via: SIP/2.0/UDP 192.168.102.10:5060;branch=z9hG4bKc3t4ob3088ggkqc206o0.1
To: <2130330>;tag=8ADD938-4DB
Date: Wed, 29 Aug 2012 05:46:43 GMT
Call-ID: 6996658680521549328-1346219270-15974
CSeq: 1 INVITE
Require: 100rel
RSeq: 8677
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Remote-Party-ID: <2130330>;party=called;screen=no;privacy=off
Contact: <2130330>
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
I can also see that there are some attributes which are a little bit strange in your SDP contained in the invite from your ITSP..
a=X-vrzcap:vbd Ver=1 Mode=FaxPr ModemRtpRed=0
a=X-vrzcap:identification bin=DSR1814q Prot=mgcp App=MG
If you are passing this SDP to cube with the SDP header pass-thru command, perhaps its creating an issue...since CUBE doesnt understand them.
Can you send traces for calls without the command? I can look at it and help you troubleshoot your transfer issues
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
I'm sorry for my huge delay on this post.
Now i tried to change config, removed pass-thru commands.
Ringback is there now, but i can't make transfer from SCCP phone to another SCCP phone when call arrives from ITSP. Pressing transfer button, second phone starts to ring, but cant complete transfer. And transfer button gets inactive.
Calling number: 4957855544
Called number: 2131500
Number 2131500 translated in CUCM to 1194 IP-Phone.
CUBE -    192.168.102.17
ITSP -      192.168.102.18
CUCM -    10.10.2.7
CUBE config:
voice service voip
mode border-element
redirect ip2ip
h323
  h245 passthru all
sip
  early-offer forced
  midcall-signaling passthru
voice class codec 1
dial-peer voice 1 voip
description ### incoming from ITSP Orange trunk2 ###
translation-profile outgoing IBB
destination-pattern 946T
session target ipv4:192.168.102.18
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1001 voip
preference 8
destination-pattern 21315..
voice-class codec 1
dtmf-relay rtp-nte
no vad
Valery,
I am glad that you are making some progress..Dont forget to rate nay useful post!
Ok on the transfer issue..There are two things I see here..
When the call was transfereed to extension 1194...A re-invite was sent out to your provider by CUCM and then they sent an unsupported media response
v=0
o=CiscoSystemsSIP-GW-UserAgent 9524 6428 IN IP4 192.168.102.17
s=SIP Call
c=IN IP4 192.168.102.17
t=0 0
m=audio 16492 RTP/AVP 18 19
a=inactive
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:19 CN/8000-------------------------------------Your provider does not seem to like this attribute
a=ptime:20
a=ptime:20
Feb  7 08:14:53.588: //236893/4485A16CAE61/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 415 Unsupported Media Type
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKAE740
To: <4957855544>;tag=21290
Call-ID: 6996658680551785828-1360224963-15298
Another thing I have see is this, the way your provider has implemented G729 anexb is different fromt the way cisco has implemented theirs. Your provider is sending G729ab in payload 96. where as CUBE sends annexb support in payload 18 with annexb=yes line.
v=0
o=MG4000|2.0 28822 28823 IN IP4 192.168.102.18
s=-
c=IN IP4 192.168.102.18
t=0 0
m=audio 50056 RTP/AVP 18 96
a=rtpmap:96 G.729ab/8000
a=ptime:20
a=X-vrzcap:vbd Ver=0 Mode=FaxPr ModemRtpRed=0
Action PLan: Speak to your sip provider and tell them what you have observed and let them tell you why they are sending unsupported media response..
The other question is what region is the 1194 extension in? Why are you changing codec during call transfer?
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi again and thanks for your help!
I revert pass-thru commands back in config, and now hold/transfer/conf between sccp phones is working. But ringing is gone, in debug i see it starts from 180 Ringing and then 183 at once.
Here are debug ccsip messages (transfer was made to 1148):
Feb  7 12:45:33.803: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2131500@192.168.102.17:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.102.18:5060;branch=z9hG4bK7h4edl30a0shcp00v6c0.1
Call-ID: 6996660879566476043-1360241211-5450
To: <2131500>
Content-Type: application/sdp
CSeq: 1 INVITE
Contact: <4957855544>
Allow: INVITE,CANCEL,BYE,ACK,REFER,UPDATE,INFO,PRACK
Supported: timer,100rel
Max-Forwards: 69
Content-Length: 309
v=0
o=MG4000|2.0 29180 29180 IN IP4 192.168.102.18
s=-
t=0 0
m=audio 50056 RTP/AVP 18 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=fmtp:18 annexb=no
a=ptime:20
Feb  7 12:45:33.811: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <2131500>
Date: Thu, 07 Feb 2013 12:45:33 GMT
CSeq: 1 INVITE
Content-Length: 0
Feb  7 12:45:33.811: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:2131500@10.10.2.7:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.253:5060;branch=z9hG4bKB1DB126C
Remote-Party-ID: <4957855544>;party=calling;screen=no;privacy=off
To: <2131500>
Call-ID: 18FD1818-705B11E2-890CD940-145A5F00@10.10.2.253
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0419159855-1885016546-2298927424-0341466880
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Timestamp: 1360241133
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 308
v=0
s=-
c=IN IP4 10.10.2.253
t=0 0
m=audio 19094 RTP/AVP 18 101
a=fmtp:101 0-15
a=fmtp:18 annexb=no
a=ptime:20
Feb  7 12:45:33.815: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <2131500>
Date: Thu, 07 Feb 2013 12:46:51 GMT
CSeq: 101 INVITE
Content-Length: 0
Feb  7 12:45:34.023: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <2131500>;tag=859894~7b97bb5c-eeaf-4aea-bd1e-affb76d2fec0-61054753
CSeq: 101 INVITE
P-Asserted-Identity: <1194>
Remote-Party-ID: <1194>;party=called;screen=yes;privacy=off
Contact: <2131500>
Content-Length: 0
Feb  7 12:45:34.023: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <2131500>;tag=B4A18280-213E
CSeq: 1 INVITE
Require: 100rel
RSeq: 9652
Remote-Party-ID: <2131500>;party=called;screen=no;privacy=off
Contact: <2131500>
Content-Length: 0
Feb  7 12:45:34.031: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:2131500@192.168.102.17:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.102.18:5060;branch=z9hG4bK71bhfu30eor05qsgu1k0.1
CSeq: 2 PRACK
RAck: 9652 1 INVITE
Max-Forwards: 69
Content-Length: 0
Feb  7 12:45:34.031: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 07 Feb 2013 12:45:34 GMT
CSeq: 2 PRACK
Content-Length: 0
Feb  7 12:45:36.499: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Session-Expires:  1800;refresher=uas
Require:  timer
Contact: <2131500>
Content-Length: 210
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 10.10.2.7
s=SIP Call
c=IN IP4 10.10.53.50
t=0 0
m=audio 22088 RTP/AVP 18 101
a=ptime:20
a=fmtp:101 0-15
Feb  7 12:45:36.503: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:2131500@10.10.2.7:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.253:5060;branch=z9hG4bKB1DC646
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb  7 12:45:36.503: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Remote-Party-ID: <1194>;party=called;screen=no;privacy=off
Contact: <2131500>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 215
v=0
s=SIP Call
t=0 0
m=audio 27766 RTP/AVP 18 101
a=ptime:20
a=fmtp:101 0-15
Feb  7 12:45:36.515: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.102.18:5060;branch=z9hG4bKnhrbni306o4hpncup2o0.1
CSeq: 1 ACK
Max-Forwards: 69
Content-Length: 0
Feb  7 12:45:38.367: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4957855544@10.10.2.253:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd4211221a016c
From: <2131500>;tag=859894~7b97bb5c-eeaf-4aea-bd1e-affb76d2fec0-61054753
To: <4957855544>;tag=B4A181AC-F86
Date: Thu, 07 Feb 2013 12:46:55 GMT
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.5
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Session-Expires:  1800;refresher=uac
Remote-Party-ID: <1194>;party=calling;screen=yes;privacy=off
Content-Length: 218
v=0
o=CiscoSystemsCCM-SIP 2000 2 IN IP4 10.10.2.7
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=inactive
a=fmtp:101 0-15
Feb  7 12:45:38.371: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 07 Feb 2013 12:45:38 GMT
CSeq: 101 INVITE
Content-Length: 0
Feb  7 12:45:38.371: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4957855544@192.168.102.18:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1DD18B7
Remote-Party-ID: <1194>;party=calling;screen=no;privacy=off
To: <4957855544>;tag=30060
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1360241138
Contact: <2131500>
Expires: 180
Content-Length: 220
v=0
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=inactive
a=fmtp:101 0-15
Feb  7 12:45:38.399: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 288
v=0
o=MG4000|2.0 29182 29182 IN IP4 192.168.102.18
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb  7 12:45:38.403: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4957855544@192.168.102.18:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1DE2579
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb  7 12:45:38.403: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Remote-Party-ID: <4957855544>;party=called;screen=no;privacy=off
Contact: <1194>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 287
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb  7 12:45:38.407: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1194@10.10.2.253:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd421247359154
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Received:
INVITE sip:1194@10.10.2.253:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd42135b6a0311
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Feb  7 12:45:38.411: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Feb  7 12:45:38.411: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1DF246
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Contact: <2131500>
Expires: 180
Content-Length: 0
Feb  7 12:45:38.419: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 317
v=0
o=MG4000|2.0 29182 29183 IN IP4 192.168.102.18
s=-
t=0 0
m=audio 50056 RTP/AVP 18 96 101
a=fmtp:101 0-15
a=ptime:20
Feb  7 12:45:38.423: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Contact: <1194>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 316
v=0
s=-
t=0 0
m=audio 19094 RTP/AVP 18 96 101
a=fmtp:101 0-15
a=ptime:20
Feb  7 12:45:38.431: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd4214609e5938
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 243
v=0
o=CiscoSystemsCCM-SIP 2000 3 IN IP4 10.10.2.7
s=SIP Call
t=0 0
m=audio 4000 RTP/AVP 18 101
a=X-cisco-media:umoh
a=ptime:20
a=sendonly
a=fmtp:101 0-15
Feb  7 12:45:38.435: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E021D4
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=ptime:20
a=sendonly
a=fmtp:101 0-15
Feb  7 12:45:41.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd421543492d5b
Date: Thu, 07 Feb 2013 12:46:58 GMT
Min-SE:  1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 239
v=0
o=CiscoSystemsCCM-SIP 2000 4 IN IP4 10.10.2.7
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=inactive
a=fmtp:101 0-15
Feb  7 12:45:41.387: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 07 Feb 2013 12:45:41 GMT
CSeq: 103 INVITE
Content-Length: 0
Feb  7 12:45:41.387: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E11A66
Min-SE:  1800
CSeq: 103 INVITE
Max-Forwards: 70
Timestamp: 1360241141
Contact: <2131500>
Expires: 180
Content-Length: 242
v=0
IP4 10.10.2.7
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=inactive
a=fmtp:101 0-15
Feb  7 12:45:41.451: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 INVITE
Content-Length: 288
v=0
o=MG4000|2.0 29184 29185 IN IP4 192.168.102.18
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb  7 12:45:41.455: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E2239B
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 0
Feb  7 12:45:41.455: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 INVITE
Contact: <1194>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 287
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb  7 12:45:41.675: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd4216c844cb7
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 0
Feb  7 12:45:42.607: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:1194@10.10.2.253:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd4217654e812e
Max-Forwards: 70
CSeq: 104 UPDATE
P-Asserted-Identity: "NSK-Voloshchuk" <1148>
Remote-Party-ID: "NSK-Voloshchuk" <1148>;party=calling;screen=yes;privacy=off
Content-Length: 0
Feb  7 12:45:42.615: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
UPDATE sip:4957855544@192.168.102.18:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E3121A
Max-Forwards: 70
Timestamp: 1360241142
CSeq: 104 UPDATE
Contact: <2131500>
Min-SE:  1800
Content-Length: 0
Feb  7 12:45:42.615: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 07 Feb 2013 12:45:42 GMT
CSeq: 104 UPDATE
Contact: <1148>
Supported: timer
Content-Length: 0
Feb  7 12:45:42.955: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd42183254bb95
Date: Thu, 07 Feb 2013 12:47:00 GMT
Min-SE:  1800
CSeq: 105 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Feb  7 12:45:42.963: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 105 INVITE
Content-Length: 0
Feb  7 12:45:42.963: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 104 UPDATE
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E4C3A
Max-Forwards: 70
CSeq: 105 UPDATE
Contact: <2131500>
Min-SE:  1800
Remote-Party-ID: "NSK-Voloshchuk" <1148>;party=called;screen=yes;privacy=off
Content-Length: 0
Feb  7 12:45:43.719: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 105 UPDATE
Content-Length: 0
Feb  7 12:45:43.731: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E5270E
Date: Thu, 07 Feb 2013 12:45:43 GMT
Min-SE:  1800
CSeq: 106 INVITE
Max-Forwards: 70
Timestamp: 1360241143
Contact: <2131500>
Expires: 180
Content-Length: 0
Feb  7 12:45:44.051: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 106 INVITE
Content-Length: 317
v=0
o=MG4000|2.0 29184 29186 IN IP4 192.168.102.18
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb  7 12:45:44.059: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 105 INVITE
Contact: <1148>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 316
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
Feb  7 12:45:44.675: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1148@10.10.2.253:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd42192f76e410
Max-Forwards: 70
CSeq: 105 ACK
Content-Length: 206
v=0
o=CiscoSystemsCCM-SIP 2000 5 IN IP4 10.10.2.7
s=SIP Call
c=IN IP4 10.10.0.7
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
a=sendonly
Feb  7 12:45:44.683: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 106 INVITE
Content-Length: 317
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E6B6E
Max-Forwards: 70
CSeq: 106 ACK
Content-Length: 214
v=0
s=SIP Call
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
a=sendonly
Sent:
Max-Forwards: 70
CSeq: 106 ACK
Content-Length: 214
v=0
s=SIP Call
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
a=sendonly
Feb  7 12:45:46.663: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1148@10.10.2.253:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd421b2cb34d7d
Date: Thu, 07 Feb 2013 12:47:04 GMT
Min-SE:  1800
CSeq: 106 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 204
v=0
o=CiscoSystemsCCM-SIP 2000 6 IN IP4 10.10.2.7
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
a=inactive
Feb  7 12:45:47.335: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 07 Feb 2013 12:45:46 GMT
CSeq: 106 INVITE
Content-Length: 0
Feb  7 12:45:47.335: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E70
Remote-Party-ID: "NSK-Voloshchuk" <1194>;party=calling;screen=yes;privacy=off
Min-SE:  1800
CSeq: 107 INVITE
Max-Forwards: 70
Timestamp: 1360241146
Contact: <2131500>
Expires: 180
Content-Length: 207
v=0
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
a=inactive
Feb  7 12:45:47.343: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 07 Feb 2013 12:45:47 GMT
Min-SE:  1800
CSeq: 107 INVITE
Max-Forwards: 70
Timestamp: 1360241147
Contact: <2131500>
Expires: 180
Content-Length: 207
v=0
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
a=inactive
Feb  7 12:45:48.191: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 107 INVITE
Content-Length: 253
v=0
o=MG4000|2.0 29186 29188 IN IP4 192.168.102.18
s=-
t=0 0
a=fmtp:18 annexb=no
a=ptime:20
Feb  7 12:45:48.195: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E82C2
Max-Forwards: 70
CSeq: 107 ACK
Content-Length: 0
Feb  7 12:45:48.199: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 106 INVITE
Contact: <1148>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 252
v=0
s=-
t=0 0
a=fmtp:18 annexb=no
a=ptime:20
Feb  7 12:45:48.951: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd421c299b95df
Max-Forwards: 70
CSeq: 106 ACK
Content-Length: 0
Feb  7 12:45:48.959: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd421d3bad59b5
Date: Thu, 07 Feb 2013 12:47:05 GMT
Min-SE:  1800
CSeq: 107 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Feb  7 12:45:48.963: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 07 Feb 2013 12:45:48 GMT
CSeq: 107 INVITE
Content-Length: 0
Feb  7 12:45:48.963: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1E915C2
Min-SE:  1800
CSeq: 108 INVITE
Max-Forwards: 70
Timestamp: 1360241148
Contact: <2131500>
Expires: 180
Content-Length: 0
Feb  7 12:45:49.555: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 108 INVITE
Content-Length: 261
v=0
o=MG4000|2.0 29186 29189 IN IP4 192.168.102.18
s=-
t=0 0
a=ptime:20
Feb  7 12:45:49.559: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 107 INVITE
Contact: <1148>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 260
v=0
s=-
t=0 0
a=ptime:20
Feb  7 12:45:50.231: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.10.2.7:5060;branch=z9hG4bKd421f39f72099
Date: Thu, 07 Feb 2013 12:47:06 GMT
Max-Forwards: 70
CSeq: 107 ACK
Content-Length: 155
v=0
o=CiscoSystemsCCM-SIP 2000 7 IN IP4 10.10.2.7
s=SIP Call
c=IN IP4 10.10.61.106
t=0 0
m=audio 25916 RTP/AVP 18
a=ptime:20
Feb  7 12:45:50.239: //242348/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:ACK sip:4957855544@192.168.102.18:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.102.17:5060;branch=z9hG4bKB1EA23DA
Max-Forwards: 70
CSeq: 108 ACK
Content-Length: 159
v=0
s=SIP Call
t=0 0
a=ptime:20
Feb  7 12:45:53.351: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:2131500@192.168.102.17:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.102.18:5060;branch=z9hG4bKnhrbni306o4hpncup2o0cd0000g10.1
CSeq: 3 BYE
Max-Forwards: 69
Content-Length: 0
Feb  7 12:45:53.355: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 07 Feb 2013 12:45:53 GMT
CSeq: 3 BYE
Reason: Q.850;cause=16
Content-Length: 0
Feb  7 12:45:53.355: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4957855544@10.10.2.7:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.2.253:5060;branch=z9hG4bKB1EBC9A
Date: Thu, 07 Feb 2013 12:45:50 GMT
Max-Forwards: 70
Timestamp: 1360241153
CSeq: 102 BYE
Content-Length: 0
Feb  7 12:45:53.947: //242349/18FBDF2F8906/SIP/Msg/ccsipDisplayMsg:
Received:  SIP/2.0 200 OK
Date: Thu, 07 Feb 2013 12:47:10 GMT
CSeq: 102 BYE
Content-Length: 0
The call that worked...You called extension 2131500, the call was then sent to 1194 (is 1194 the same as 231500) and you then xfered to 1148...
Can you try something...
1. Remove the pass-thru sdp headers
2. disable PRACK on CUBE and sip trunk
3. test again
Yes 2131500 is translated to 1194 in cucm.
Did you mean to exec 'sip rel1xx disable' on cube? And same on sip trunk at cucm side in trunk profile setting?
I'll try it tomorrow and update this post with results of ringback issue.
Yes disable relxx on both cucm and cube
Hi again.
Here my investigation.
On CUCM trunk rel1xx is disabled by default.
I issued next commands on cube to disable PRACK and sdp headers:
msk-sip-gw(conf-serv-sip)#rel1xx disable
msk-sip-gw(conf-serv-sip)#no pass-thru headers unsupp
After that nothing changed, ringback still missed. Call starts with 180 Ringing and then 183 Sessing progress (debug output in prack_headers_disabled.txt)
Then i tried to issue next command in addition to previous:
msk-sip-gw(conf-serv-sip)#no pass-thru content sdp
And ringback is back! (debug in prack_headers_sdp_disabled.txt).
But after i issued last command, incoming DTMF is broken. And also i cant hold/transfer/conf incoming calls.
In continuation of my issue, I want to say that I have another voice router in another city, which is connected to the same ITSP provider.
And there's an identical config (i mean it contains strings pass-thru headers unsupp and pass-thru content sdp) and ringback is working. Config files are identical, but different versions of IOS. First router with troubles is c2900-universalk9_npe-mz.SPA.151-2.T4.bin, and second c2900-universalk9_npe-mz.SPA.151-3.T1.bin.
I'm also attaching debug with ringback of second router (nsk_with_ringback.txt)
So, it seems that I found the issue.
After upgraded first router from 151-2.T4 to 151-3.T1 i've incoming ringback! And hold/transfer/conf if working now!
Config on both routers now is:
!output skipped
sip
Thanks for assistance!
Ayodeji Okanlawon
Great job. Valery and thanks for updating us. Can you send the trace for the working calls now especially with transfer. I will like to compare the logs
Sent from Cisco Technical Support Android App
