SIP outgoing call one way voice
Humza Khan
Call flow is like.
SIP on Switch==> Router==> CORE==> CUCM.
Sip Proxy:10.200.28.181.
Our SIP IP:10.200.24.162
GW:10.200.24.161
CM IP:10.120.100.1
Core SW route: ip route-static 10.200.28.181 255.255.255.255 (10.0.XX.35) (Router IP)
Outbound call is working. but with one way voice. Inbound operator can hear us, but pstn user cannot hear hear operator voice.
Route added on core for sip proxy as well, but issue remains. Logs attached.
Kindly suggest.
HK
Ayodeji Okanlawon
99% of the time oneway audio is down to routing issue..
Here is the analysis of your media connection
Source IP Address (Media): 10.200.24.162--cube external int
Source IP Port    (Media): 17156
Destn  IP Address (Media): 10.200.28.182--itsp ip
Destn  IP Port    (Media): 35270
Can this two IP talk to each other?
Source IP Address (Media): 10.0.40.35--cube internal ip
Source IP Port    (Media): 17994
Destn  IP Address (Media): 10.120.100.1-----endpoint ip
Destn  IP Port    (Media): 30492
Please rate all useful posts
Ayodeji Okanlawon
Hi Ayodeji,
Thanks for sharing analysis, i check this thing. 10.0.40.35 and 10.120.100.1 can talk to each other. But 10.200.28.182 can even ping. So just now i have entered route command for 182 as well router and tested now operator voice is working now but mobile user ring and discussion is dead.
I thinking to add same 182 route in core as well. But doesn't seems ok to me.
Kindly suggest.
HK
Issue resolved  by adding routes on router.
ip route 10.200.28.182 255.255.255.255 10.200.24.161
ip route 0.0.0.0 0.0.0.0 192.168.100.180
Thanks for your entire support.
HK
+ 5 to Ayodeji..  This link may help you to troubleshoot the issue, Please check
http://www.cisco.com/c/en/us/support/docs/voice/voice-quality/5219-fix-1way-voice.html
Lavanya
