Sip Phone On differenet Subnet with CME
recep.sefer
7911 Sip Phone on same Subnet with CME register and works
but
7911 Sip Phone on different Subnet with CME cannot register
There is no NAT, Firewall, VPN
9 Replies 9
acampbell
Can any device from the remote subnet ping the CME.
Are all the DHCP parameters set up like
default gateway & TFTP server (option 150)
Alex
Regards, Alex. Please rate useful posts.
Telephone can ping CME from remote side,
There is no problem with IP connectivity,
Remote telephone is provisioned like local
It is seemed to be registered by CME
But telephone displays "REGISTERING" always
Here is CME debug output
000223: Aug 19 19:20:17.128: TFTP: Looking for CTLSEP108CCF7569A6.tlv
000224: Aug 19 19:20:17.248: TFTP: Looking for SEP108CCF7569A6.cnf.xml
000225: Aug 19 19:20:17.248: TFTP: Opened
system:/cme/sipphone/SEP108CCF7569A6.cnf.xml, fd 13, size 2892 for process
248
000226: Aug 19 19:20:17.256: TFTP: Finished
system:/cme/sipphone/SEP108CCF7569A6.cnf.xml, time 00:00:00 for process 248
000227: Aug 19 19:20:19.572: TFTP: Looking for
English_United_States/tc-sip.jar
000228: Aug 19 19:20:19.768: TFTP: Looking for United_States/g3-tones.xml
000229: Aug 19 19:20:20.072: TFTP: Looking for softkeyDefault_kpml.xml
000230: Aug 19 19:20:20.072: TFTP: Opened
system:/cme/sipphone/softkeyDefault_kpml.xml, fd 13, size 4093 for process
248
000231: Aug 19 19:20:20.100: TFTP: Finished
system:/cme/sipphone/softkeyDefault_kpml.xml, time 00:00:00 for process 248
000232: Aug 19 19:20:20.804: VOICE_REG_POOL: Register request for (779) from
(192.168.10.11)
000233: Aug 19 19:20:20.808: VOICE_REG_POOL: Contact matches pool 4 number
list 1
000234: Aug 19 19:20:20.808: VOICE_REG_POOL: key(779) contact(192.168.10.11)
add to contact table
000235: Aug 19 19:20:20.808: VOICE_REG_POOL: key(779) exists in contact
table
000236: Aug 19 19:20:20.808: VOICE_REG_POOL: contact(192.168.10.11) exists
in contact table, ref updated
000237: Aug 19 19:20:20.808: VOICE_REG_POOL: Created dial-peer entry of type
000238: Aug 19 19:20:20.808: VOICE_REG_POOL: Registration successful for
779, registration id is 6
000239: Aug 19 19:20:20.808: VOICE_REG_POOL: Pool[4]: service-control (reset
type: 2) message sent to sip:779@10.1.1.11
000240: Aug 19 19:20:20.808: VOICE_REG_POOL: Contact matches pool 4 number
list 1
THANKS
Try following this link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_phreg.html#wp1054191
Alex
mattcalderon
Level 4
Level 4
bind SIP to an interface
voice service voip
sip
bind all source
session-transport tcp  under pool solves my problem
I cannot understant why?
thanks
voice register pool  3
id mac 04C5.A4B0.99A1
type 7911
number 1 dn 3
yes, "session-transport tcp" solves the problem.
I try the same command for SRST SIP CME mode, unfortunately it could not solve the problem. Is there any command to solve it?
Please advise
paolo bevilacqua
For 79xx phones, use SCCP not SIP. You will enjoy more features and less trouble.
My customer used 3905 which was only support SIP for it. Actually, when I use "id network x.x.x.x" command under "voice register pool", it can work properly. Now I want set the voice register pool using "id mac" in order to speed up the configuration when the WAN is down. Is it possible?
When we run in "mode srst" there is no "session-transport tcp" can be put in "voice register pool".
Please advise
As above, 79xx supports SCCP and that the way they are to be used.
For 3905 in SIP, you n to make sure there is no firewall in between phone and CME. If there is, you need to disable it. Phone will have to use UDP, not TCP.
