SIP Phones register but cant make calls to each other
nitesz010
Am I missing something in the following configs? The phones are able to register but cant make calls to each other? Is there anything I need to add to the config to be able to make calls?
Current configuration : 8173 bytes
! Last configuration change at 20:35:57 UTC Tue Feb 2 2016 by wachter
version 15.4
hostname KCC-CUCME-2921
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging buffered 51200 warnings
enable secret 5 $1$fner$un2VRxsPt6gy418Fm/tHz.
no aaa new-model
ip dhcp pool VOICE
 network 192.168.2.0 255.255.255.0
 dns-server 4.4.4.4 8.8.8.8
 default-router 192.168.2.1
 option 150 ip 192.168.2.1
 lease infinite
ip domain name kccoring.local
ip cef
no ipv6 cef
cts logging verbose
crypto pki trustpoint TP-self-signed-1027156387
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1027156387
 revocation-check none
 rsakeypair TP-self-signed-1027156387
voice-card 0
voice service voip
 ip address trusted list
  ipv4 192.168.0.0 255.255.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/0.20
  bind media source-interface GigabitEthernet0/0.20
  registrar server expires max 600 min 60
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
 codec preference 3 ilbc
voice register global
 mode  cme
 source-address 192.168.2.1 port 5060
 max-dn 25
 max-pool 25
 timezone 8
 tftp-path flash:
 create profile sync 0042525408078253
 encapsulation dot1Q 20
 ip address 192.168.2.1 255.255.255.0
interface ISM0/0
 ip unnumbered GigabitEthernet0/0.20
 ip virtual-reassembly in
 service-module fail-open
 service-module ip address 192.168.2.5 255.255.255.0
 service-module ip default-gateway 192.168.2.1
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface ISM0/1
 no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 192.168.2.5 255.255.255.255 ISM0/0
tftp-server flash:kern2.78xx.11-0-1-11.sbn
tftp-server flash:kern78xx.11-0-1-11.sbn
tftp-server flash:rootfs2.78xx.11-0-1-11.sbn
tftp-server flash:rootfs78xx.11-0-1-11.sbn
tftp-server flash:sboot2.78xx.11-0-1-11.sbn
tftp-server flash:sboot78xx.11-0-1-11.sbn
tftp-server flash:sip78xx.11-0-1-11.loads
tftp-server flash:its
tftp-server flash:copstart.sh
tftp-server flash:load36213.txt
tftp-server flash:load621.txt
tftp-server flash:load622.txt
tftp-server flash:load623.txt
access-list 23 permit 10.10.10.0 0.0.0.127
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
go to respective voice register pool <X> and configure 'no digit collect kpml
example
voice register pool 1
codec g711u
reset
then go to voice register global and perform no create profile and create profile
Br,
Nadeem Ahmed
Please rate all useful post.
Br, Nadeem Please rate all useful post.
10 Replies 10
Rajan
What is the exact behavior when you try to make between internal extensions ? Could you also provide "debug ccsip messages" for one failed call along with call details to check.
Rajan
Hello Rajan,
Here is the outcome of "debug ccsip messages".
Received:
INVITE sip:7@192.168.2.1;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.2.19:5060;branch=z9hG4bK29321227
From: "7151" <sip:7151@192.168.2.1>;tag=f0b2e57888a8008437dbbe0b-70ddaadf
To: <sip:7@192.168.2.1>
Call-ID: f0b2e578-88a80011-1aa37d8a-173b6768@192.168.2.19
Max-Forwards: 70
Session-ID: 5bb5557000105000a000f0b2e57888a8;remote=00000000000000000000000000000000
Date: Wed, 03 Feb 2016 15:08:39 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP7841/11.0.1
Contact: <sip:52CDEFDC-17F7@192.168.2.19:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEPF0B2E57888A8"
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "7151" <sip:7151@192.168.2.1>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 349
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 26241 0 IN IP4 192.168.2.19
s=SIP Call
b=AS:4064
t=0 0
m=audio 31510 RTP/AVP 0 8 116 18 101
c=IN IP4 192.168.2.19
b=TIAS:64000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
*Feb  3 15:08:39.149: //1122/D6EBBB118539/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.4.3.M3
Content-Length: 0
*Feb  3 15:08:39.197: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:7@192.168.2.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.19:5060;branch=z9hG4bK62c71a55
To: <sip:7@192.168.2.1>;tag=713FF158-19AD
From: <sip:7151@192.168.2.19>;tag=f0b2e57888a80085357a1cc5-2f0948d0
Call-ID: D6ECF361-C9BE11E5-853EB5E4-44427891@192.168.2.1
Session-ID: 8fa3e36800105000a000f0b2e57888a8;remote=00000000000000000000000000000000
CSeq: 1000 NOTIFY
Event: kpml
Subscription-State: active; expires=7200
Max-Forwards: 70
Content-Length: 0
*Feb  3 15:08:39.329: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.2.19:5060;branch=z9hG4bK2a289f0f
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Content-Type: application/kpml-response+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="1" tag="Backspace OK"/>
*Feb  3 15:08:39.509: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.2.19:5060;branch=z9hG4bK50b44c32
CSeq: 1002 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="4" tag="Backspace OK"/>
*Feb  3 15:08:39.705: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.2.19:5060;branch=z9hG4bK2d4f0ace
CSeq: 1003 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="7" tag="Backspace OK"/>
*Feb  3 15:08:39.713: //1122/D6EBBB118539/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:7@192.168.2.1>;tag=713FF38C-A2E
CSeq: 101 INVITE
Warning: 399 192.168.2.1 "Transcoder Not Configured"
Reason: Q.850;cause=47
Content-Length: 0
*Feb  3 15:08:39.737: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:7@192.168.2.1;user=phone SIP/2.0
Max-Forwards: 70
Date: Wed, 03 Feb 2016 15:08:40 GMT
CSeq: 101 ACK
Content-Length: 0
*Feb  3 15:08:39.757: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.2.19:5060;branch=z9hG4bK0420d32a
CSeq: 1004 NOTIFY
Event: kpml
Subscription-State: terminated; reason=timeout
Max-Forwards: 70
Content-Length: 218
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="487" text="Subscription Exp" suppressed="false" forced_flush="false" digits="" tag="Backspace OK"/>
example
codec g711u
reset
Br,
Nadeem Ahmed
Thanks Nadeem. That worked.
Hi Nadeem,
I have the same issue with Cisco 8861 model SIP Phones.
I try to do your solution, it is not allow me to issue with this command
abc(config-register-global)#no profile
% Invalid input detected at '^' marker.
I am still have not over come this issue, any help would be much appreciated ?
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.168.17.67:5060;branch=z9hG4bK7E1089
To: <sip:+012803003511@10.172.151.55>;tag=40a6e8b0730e004842a384ef-1e0a58d9
Call-ID: D736D36B-FA0E11E5-A193F1E8-7004A6EB@10.168.17.67
Session-ID: 79d47c5f00105000a00040a6e8b0730e;remote=00000000000000000000000000000000
Date: Tue, 05 Apr 2016 02:42:15 GMT
CSeq: 101 REFER
Server: Cisco-CP8861/11.0.1
Contact: <sip:53fdd314-0801-2b69-5e68-ad67c4397945@10.172.151.55:5060;transport=udp>
Content-Length: 0
Its
#voice register global
#no create profile
#create profile
You are doing #no profile only and getting error.
sorry for the confusion, it was my typo...... I don't have the option ???
RB3003AC1(config-register-global)#no create profile
RB3003AC1(config-register-global)#no c?
call-forward
Can you please provide me the show run and show version from your router
Nadeem
Sorry for the delay, Cisco accepted as it is a Firmware issue with 8861 version 11.0
They are in the process for fixing it
Have  you opened any TAC case?
